J Custom Gotoh strap locks problems - Jemsite
post #1 of 5 (permalink) Old 04-11-2015, 09:44 AM Thread Starter
metalhead52's Avatar
Wondering if anyone else has issues with the strap pins coming loose. Seemingly for no reason the pin on the upper horn just unscrews itself. The hole is not stripped. It just comes unscrewed. Last night after band practice, it was almost completely unscrewed. I had just tightened it after it was coming unscrewed sitting in the case for a week. Should I try and wrap the screw with pipe tape? Is there a good fix for this?
metalhead52 is offline
post #2 of 5 (permalink) Old 04-11-2015, 10:28 AM
Re: J Custom Gotoh strap locks problems
Yes, I've had that problem. I retrofitted a set on my '99 FP. I was having the same problem with the upper horn. It would be loose by the end of an hour guitar lesson. I put a tiny dab of wood glue down near the tip of the screw and screwed it in. It's been totally solid since.
Takin' a Ride is offline
post #3 of 5 (permalink) Old 04-11-2015, 10:29 AM Thread Starter
I'll give that a try. Just didn't want to make it permanently locked in there.
post #4 of 5 (permalink) Old 04-11-2015, 10:48 AM
I always recommend fixing stripped threads with CA and accelerator. I use an E string and run a few drop around the inside to coat the threads. It swells the original threads and adds thickness, and accelerator it's hard as rock and a lifetime fix.
Rich is offline
post #5 of 5 (permalink) Old 04-11-2015, 12:25 PM
This isn't a stripped thread thing. It just backs the screw out enough to make the strap pin loose.
Wood glue should not stick to the threads of the screw and you should ultimately be able to back it out in the future. With metal I'd use Loc-tite but I didn't think that would work for wood. I used a very small amount of wood glue, just enough to barely coat the screw. Like you, I didn't want to make it permanently in there or mess anything up.
That said, Rich's method should work too. Basically you'd be creating a tighter fit and therefore more friction between the wood and the screw. I think the problem currently is that there's more friction between the screw and the strap pin than there is between the screw and the wood. As you move around while you're playing, you just begin to unscrew the thing.
Gotoh strap locks on j customs lorper All Other Guitars (including Prestige) 3 08-29-2014 06:59 PM
Who needs strap locks...LOL!!! jl2556 Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 10 12-14-2013 05:31 PM
WTB: Strap Pins, Gotoh Strap Locks and Speed Knobs in Pearl Gold Ruslan Classified Ads: Guitars and Gear 1 11-25-2010 12:18 PM
J-custom strap locks (1990's style recessed) - how can i fix them to the strap? Dan_H All Other Guitars (including Prestige) 3 02-07-2009 03:33 PM
Gotoh strap locks - Installation instructions? kuma Tech: Setup, Repairs and Mods 3 03-13-2001 01:16 PM
