Jem 505 edge trem hits body when pulling back - Jemsite
post #1 of 3 (permalink) Old 03-08-2015, 12:36 PM Thread Starter
A couple of weeks ago I bought a new-old Jem 505 that had been hangning at the back of a music store for years and years. It's my first guitar with a floyd-like trem since I was a teenager and my first ever edge trem. It's a great guitar.
But I have a problem with the trem. I have it set to a string height of a comfortable 1.5mm on the bass side and the same on the treble side, and if I try to pull back on the trem it seems to hit the wood of the "shelf" in the trem route where the studs are placed. I can pull up a little more than a semitone before it something and stops. It's like the trem cavity isnt routed deep enough to allow the trem to move at that string height.
Is this normal? I was under the impression that I would have a lot more wiggle-room with the trem than that.
(the board wont allow me to post a photo or a link to a photo)
brutalisator is offline
post #2 of 3 (permalink) Old 03-08-2015, 01:57 PM
Re: Jem 505 edge trem hits body when pulling back
http://www.ibanezrules.com/tech/grunge/grunge_6.htm
You'll also never get a perfect fourth of pullup range out of any Ibanez with low action without adding a shim.
wilch is offline
post #3 of 3 (permalink) Old 03-08-2015, 02:12 PM Thread Starter
Thank you! I did read his setup guide but I never throught to read the "clean up a used ibanez" segment. I now have three choices:
1. Shim the neck, which is a shame since the fit is really good
2. Route the cavity deeper and mount the studs deeper
3. Just leave it alone
I think I'll go with #3 for now although #2 seems like a lot of fun to do
Pulling Trem Anchors? Fastmerc Tech: Setup, Repairs and Mods 8 05-23-2013 11:49 AM
How can I check whether my RG2570 body takes an Edge Pro or Edge Zero trem? JayCartay All Other Guitars (including Prestige) 6 11-18-2012 06:23 PM
Tut: Removing a Broken Trem Arm w/o Pulling the Trem (pics) SonataGuitarist Tech: Setup, Repairs and Mods 11 05-10-2007 02:57 AM
Another Tragedy Hits Broncos Family - Running Back Dies JJEMMER777 Off-topic / Miscellaneous 1 02-25-2007 07:54 PM
Change in action while pulling back trem? Drew Tech: Setup, Repairs and Mods 32 07-12-2002 04:46 PM
