JEM Problem - Jemsite
post #1 of 2 (permalink) Old 06-25-2004, 04:29 AM Thread Starter
JEM Problem
Hey guys, I have a JEM and I have a minor problem with it and was wondering if anyone can help.
Basically the problem is, if I play a note, e.g. on the 12th fret of the high E, hold that note and then play a note on the B string while the E string note is still playing...you with me? Then the B string note sounds all fuzzy and...crap. I can't figure out why its doing it...maybe something to do with the pickups? I've tried it with both humbuckers and the single coil but the noise it makes is always the same.
Can anyone help me?
Thanks
Reath is offline
post #2 of 2 (permalink) Old 06-25-2004, 03:28 PM
T-O-N-E
try adjusting your distortion settings.
(assuming you're using it)
clean it up a bit (back-off the gain)
or
max the gain out. then everything will be so fuzzy that it won't matter!
SRVoodoo is offline
problem with PM's? evolvedmb Forum Announcements and Member Help 0 03-17-2008 06:30 AM
problem with EMG ZW set kral Pickups & wiring 1 09-02-2004 05:22 AM
Wierd Lo-Pro Edge 7 problem... big problem! Jupiter Tech: Setup, Repairs and Mods 5 06-11-2003 01:43 PM
UV777BK trem problem - I think it is a problem (shrug) Scoff X Tech: Setup, Repairs and Mods 5 09-21-2001 12:59 AM
Any problem setting up for BEADGB? - Any problem setting up Pudreaux Ibanez JEM, UV, JS & Other Signature Models 2 06-28-2001 02:56 PM
