JEM7VWH action high need help - Jemsite
post #1 of 12 (permalink) Old 01-22-2013, 07:24 AM Thread Starter
i have ibanez jem7vwh 2008 model..ive adjusted the neck and bridge but the action is still too high....ive heard about neck shim and nut shim all that but i dont know what that is..can anyone help me with that?any diagram or picture to show on neck shim or nut shim?
what i have to do? ive include pictures of the guitar below
djanggo is offline
post #2 of 12 (permalink) Old 01-22-2013, 09:06 AM
Re: JEM7VWH action high need help
Yes it looks like you need a shim on the body side of the neck pocket. About the thickness of a business card folded once to start with and about 1/2" wide right at the end of the neck. This will change the angle of the neck and allow you to raise the trem up a little and get the action lower at the heel end of the neck...
Swirltop is offline
post #3 of 12 (permalink) Old 01-22-2013, 09:03 PM Thread Starter
Ive done it.. I put the folded in two card in between the 4 screws of the neck joint... Slightly better action after that...thank you
djanggo is offline
post #4 of 12 (permalink) Old 01-23-2013, 09:44 AM
Did you put it in the middle of the screws? It should have gone on the end near the neck pickup side. That will change the angle and allow for better action. If you put it in the middle it won't have the desire effect..
Swirltop is offline
post #5 of 12 (permalink) Old 01-23-2013, 09:48 AM Thread Starter
But its just a small space.... Cant fit the card...
djanggo is offline
post #6 of 12 (permalink) Old 01-23-2013, 09:54 AM
You don't have to put the whole card in there, that's just an example of the thickness to start out with. Cut it to make it fit about the size of the rectangle in that pic. If a screw goes through it it's fine. You need the heel end to be raised up a little higher to change the angle of the neck
Swirltop is offline
post #7 of 12 (permalink) Old 01-23-2013, 09:56 AM Thread Starter
Ok i do it again and see how it goes
djanggo is offline
post #8 of 12 (permalink) Old 01-23-2013, 11:22 AM Thread Starter
ok done....yes the feel of the strings and frets feels better
djanggo is offline
post #9 of 12 (permalink) Old 01-23-2013, 11:25 AM Thread Starter
thank you for helping me out with the picture
djanggo is offline
post #10 of 12 (permalink) Old 01-23-2013, 11:26 AM
Good... You can add a little more thickness if you need to to get the action lower. Glad its playing a little better for you
Swirltop is offline
post #11 of 12 (permalink) Old 01-23-2013, 11:32 AM Thread Starter
definitely better...even with my bridge set within the line of edge pro the action is just nice for shredding and bending 2,3 notes higher without choke....i still have more allowance to lower the bridge below the line indicator....thanks for the help
djanggo is offline
post #12 of 12 (permalink) Old 01-23-2013, 11:43 AM
No problem man glad I could help! Enjoy the shred
Swirltop is offline
Jem 7v Action to high help! eatsleepplayguitar Ibanez JEM, UV, JS & Other Signature Models 31 10-10-2007 08:09 PM
High Action waylay00 Tech: Setup, Repairs and Mods 45 07-21-2007 03:56 PM
high action or just me? marshall Ibanez JEM, UV, JS & Other Signature Models 4 12-16-2003 08:38 AM
High action - what else can I do?? yurich Tech: Setup, Repairs and Mods 3 03-12-2002 10:12 PM
Action...how high or low? - where do you like diek Tech: Setup, Repairs and Mods 7 11-04-2001 10:31 PM
