Jet King 2 replacement. - Jemsite
post #1 of 6 (permalink) Old 04-24-2018, 05:37 PM Thread Starter
Hello all.
I have a 2004 JTK2 , the one with one piece neck and 2 Super 58s.
I had been trouble setting it up, took it 3 times to luthiers to no avail until the 4th found out the neck was twisted. Can't think of a reason why the other hadn't seen it.
Well, the issue is that this JTK neck is almost exclusive to this model which also have the easy access joint, without a backplate.
Scale length is 648mm/ 25" and radius is 305mmR/ 12".
Has anyone ever replaced the neck of a JTK with one from another non-JTK model ?
Thanks
soldout is offline
post #2 of 6 (permalink) Old 04-26-2018, 09:04 PM
Originally Posted by soldout View Post
Hello all.
Thanks
It probably has the same bolt pattern as the RG & Sabre. Maybe try to find a cheap RG neck on eBay. I've replaced RG necks like this, sometimes shimming is required.
snaggleyoda is offline
post #3 of 6 (permalink) Old 04-28-2018, 04:10 PM Thread Starter
Re: Jet King 2 replacement.
Hello.
I'll try an RG550 neck that's been offered to me. Thanks a lot.
soldout is offline
post #4 of 6 (permalink) Old 04-28-2018, 04:14 PM
Hello.
If the screw holes are a little bit off, don't force it. There's a brass insert kit that works great for such projects.
post #5 of 6 (permalink) Old 04-28-2018, 09:35 PM
so the issue you are going to run in to is that the 550 neck is 25.5 inch scale with 24 frets and very little overhang on the neck versus yours jet king which is only 22 frets with no overhang. The 550 neck probably won't match up scale wise. Your better bet is going to be using an s or sa neck, something that is 25.5 inch scale 22 frets.
j.arledge is offline
post #6 of 6 (permalink) Old 05-02-2018, 02:55 PM Thread Starter
Thanks a lot
soldout is offline
jet king neck jtk2
FS: Ibanez LACS Los Angeles Custom Shop Jet King ModernGuitarist Classified Ads: Guitars and Gear 1 01-12-2014 09:43 PM
WTB: Jet King or Talman nightfiend14 Classified Ads: Guitars and Gear 2 10-08-2013 01:20 AM
Jet King II MatiasTolkki All Other Guitars (including Prestige) 22 02-02-2013 12:44 AM
Ibanez Jet King JTK1 GuitAust All Other Guitars (including Prestige) 0 11-04-2006 08:43 AM
Jet King bammbamm All Other Guitars (including Prestige) 7 04-10-2004 05:56 AM
