Just a few questions about fretboard cleaning - Jemsite
post #1 of 7 (permalink) Old 09-17-2004, 07:29 AM Thread Starter
I heard lemon oil is bad for the fretboard, What is a good oil to use for rosewood?
How do you remove the leftover 0000 steel wool thats wedged inside the grain of the rosewood? my fretboard looks sparkly and I considered taking a can of compressed air to blow it out but im afraid that the can might spray out some liquid and ruin the fretboard.
What soultion should i use to rub on the fretboard with the 0000 steel wool?
Dr Mindcrime is offline
post #2 of 7 (permalink) Old 10-24-2004, 06:49 PM
I just use Murphy's wood soap. It works well, leaves it looking nice and clean, and smells pleasant, too. You don't have to use too much, but it won't hurt anything if you do, just rub it in and wipe it off with a paper towel or something.
As for the wool residue, you could probably _lightly_ scrape the fretboard with a razor, and then run a corner of the razor down the edges of the frets to clean the rosewood dust. I would do this before soaping up the fb.
jgdove is offline
post #3 of 7 (permalink) Old 10-24-2004, 08:17 PM
i used to use this foamy wood cleaner made by pledge i think, it smelled of lemon, but i don't believe it was lemon oil.. it cleaned up the fretboard quite nicely when i used an old toothbrush with it... and the strings got cleaned too, all the grime would come off them... i should get another can of that stuff...
Elysian is offline
post #4 of 7 (permalink) Old 10-25-2004, 12:57 PM
Raw linseed oil should do the trick - just remember to throw out the cloths you use directly after using them...
ThomasBJ is offline
post #5 of 7 (permalink) Old 10-25-2004, 01:03 PM
Linseed oil is a varnish, only use if you want to varnish your fretboard [personally I'd avoid klike the plague]
Rich is offline
post #6 of 7 (permalink) Old 10-25-2004, 02:08 PM
use a old toothbrush to clean the steal wool out of the fretboard!
Scott 74 is offline
post #7 of 7 (permalink) Old 10-26-2004, 11:53 PM
if the wool's not stuck too tight in there...i say a vaccum cleaner...
bobojem is offline
steel wool
Cleaning my Fretboard !! mattacuk All Other Guitars (including Prestige) 9 05-04-2008 11:19 AM
Cleaning a Maple Fretboard Ironjose Tech: Setup, Repairs and Mods 4 04-15-2007 01:41 AM
Fretboard cleaning NeglectedField All Other Guitars (including Prestige) 10 05-30-2006 09:21 AM
fretboard cleaning Drache713 Tech: Setup, Repairs and Mods 2 09-17-2004 10:20 AM
Fretboard Cleaning DiminisheD-7th All Other Guitars (including Prestige) 2 08-23-2004 06:01 PM
