Lateral play in Gibraltar-III retrofit: need advice - Jemsite
post #1 of 3 (permalink) Old 03-23-2004, 12:12 PM Thread Starter
stratoskier's Avatar
Hi,
I'm working on a project where (among other things) I'm replacing a wrap-around style bridge with a string-through setup. I'm referring to the style similar to what's on the Ibanez SZ series or Schecter C-series, where the strings are loaded from the rear, pass through ferrules to the front of the body, and then over a tunematic style bridge.
I bought an Ibanez Gibraltar III style (SZ series) bridge which is unique in that the stud spacing closely matches the 3-1/4" spacing found on many wrap-around style bridges and tailpieces. This differs from most tunematic-style bridges, which have a ~2.9" spacing.
My problem is that although the spacing is very close, there is a small (~2mm) amount of lateral play when I set the G-III bridge in place. I'm wondering if this amount of play might be acceptable, or if it would be a "deal killer" in terms of using the original anchor holes? I'd obviously prefer to not have to pull the old anchors and redrill just to make up 2mm of slack, but I'm concerned that everytime I bend a string, the bridge might shift side-to-side. It's possible that once I string it up, the string tension will hold the bridge firmly in place, but I'm not sure how much that'll help for lateral motion. Plus I can't string it up until I drill the holes for the ferrules and if this bridge isn't gonna work, I might end up staying with the original wraparound bridge.
Anyone with advice?
Thanks,
Bert
stratoskier is offline
post #2 of 3 (permalink) Old 03-23-2004, 04:34 PM
String through the body will put enough downward pressure on that bridge to keep it in place. A trapeze tailpiece or a stop bar tailpiece that was set too high wouldn't. You could fashion a couple shims out of brass or even toothpicks to lock it in place. I thought the Gibraltars could be locked in place from the top. You could also drill and tap for little allen screws like the tonepros.
frankfalbo is offline
post #3 of 3 (permalink) Old 03-23-2004, 05:13 PM Thread Starter
Thanks Frank! I figured you'd be the first to respond. I didn't notice any way to lock the Gibraltar in place, but I'll check again tonight. I thought about using some little shims to take up the slop. I'll see if I can find some thin strips of brass to wrap around the posts.
Actually, I've gone back and forth about using the original wrap-around bridge versus the string-through design, but it seems like the string-through is currently the rage, so I'd like to give it a try. At first, I didn't think it'd be possible to do the conversion because every tunematic bridge I checked had the narrower stud spacing. It's strange that Ibanez designed the G-III with 3-1/4" spacing (plus the stud threads are exactly the same as the original Shortstop II threads), but it works out well for me in this case.
matic bridge , string tension
Violin - i wanna learn to play it - advice? Fender868 All Other Guitars (including Prestige) 3 02-27-2008 12:33 PM
EDGE PRO RETROFIT USRG_DG Tech: Setup, Repairs and Mods 6 02-19-2008 11:58 PM
Anybody here regularly play a baritone guitar? Advice! vaijem777 All Other Guitars (including Prestige) 8 12-29-2003 03:50 PM
Can I retrofit my bridge? Toolhead All Other Guitars (including Prestige) 0 01-25-2003 12:27 AM
Any way to retrofit piezos in a lo-pro? - Piezo retrofit for Bob1 All Other Guitars (including Prestige) 11 04-22-2002 02:34 PM
