A lefty neck on a righty guitar? - Jemsite
post #1 of 12 (permalink) Old 12-08-2006, 12:36 PM Thread Starter
Hey guys, maybe one of you can help...
Working on a strat project, got the body done.... pickups installed..etc..etc..
Thinking about buying a lefty Fender strat neck to put on this righty Fender strat body.
Why?
I like the reverse headstock look (I wouldn't want it on everything, but one 1 thing is cool) and I have realized that I can buy a heck of alot more neck in a lefty, than I can a righty.
On a Fender, is there any problem that I am not recognizing?? ie: The string tree's that would normally have high E and B strings on them, would now have the Low E and A....is this a problem? can they accomidate the fatter strings??
I know Fender has a custom shop guitar that comes with a lefty neck, on a righty body...so I know this can be done, but can I do it right, and very easy?
Thanks!
Queens_Brian_May is offline
post #2 of 12 (permalink) Old 12-08-2006, 12:44 PM
Re: A lefty neck on a righty guitar?
Fender necks aren't a problem. Because the neck joint is square. The string trees are not a problem either. The nut however should be changed.
Koss is offline
post #3 of 12 (permalink) Old 12-08-2006, 12:45 PM
Sabre's Avatar
Beleive it or not, apparently string trees aren't even necassary, as seen on the EJ Sig Strat.
Sabre is offline
post #4 of 12 (permalink) Old 12-08-2006, 12:46 PM Thread Starter
Great point Koss... thats why I love Jemsite. I forgot about the nut.
Not to sound dumb.... but how hard is it to change the nut?
Thanks
post #5 of 12 (permalink) Old 12-08-2006, 12:55 PM
bluealien's Avatar
Thanks
On a strat , its usally glue in place, so you will have to break the hold.
Take a flat block and lay it alongside the nut (fretboard side) and give the block a sharp "tap" with a hammer. The nut should just pop out. Clean up the area of any glue residue. Your best bet is to take the old nut along with you when you buy the replacement. Try to match it up as perfect as you can, keeping in mind length, height and string spacing. You might need to modify the new one slightly. If its too high I would suggest sanding the bottom down with sandpaper on a flat surface. Make sure its sanded evenly and the end result is flat. A couple drops of superglue should be sufficient to hold it in place.
Hope this helps...
bluealien is offline
post #6 of 12 (permalink) Old 12-08-2006, 01:03 PM
When I changed the nut out on my Telecaster the fit was so snug I just set it in there and didn't even glue it. That was after a few minutes of sanding to get it to fit.
sixtywattman is offline
post #7 of 12 (permalink) Old 12-08-2006, 01:18 PM
Keep in mind that a left neck's side dots are going to be on the high-e side when mounted on a righty body, so you'll probably have to sort out a solution for that.
Demiurge is offline
post #8 of 12 (permalink) Old 12-08-2006, 02:38 PM
bluealien's Avatar
Sharpie?
post #9 of 12 (permalink) Old 12-08-2006, 03:01 PM
+1
Regards
André
fettouhi is offline
post #10 of 12 (permalink) Old 12-08-2006, 04:31 PM
Originally Posted by bluealien View Post
Sharpie?
Sure... or I think www. fretwear .com makes abalone decal side-dots ... or the LED side dots that are sold on the 'bay
Demiurge is offline
post #11 of 12 (permalink) Old 12-08-2006, 04:57 PM
its really easy to not have side dots, just look at the board inlays....I thought I would have trouble without them but I got used to it really easy.
Lefty Robb is offline
post #12 of 12 (permalink) Old 12-11-2006, 07:20 AM
Reviews: 34
Ok I have done this with two guitars and it works fine.
1st was a usa strat neck onto a custom strat body. Everything worked fine.
2nd was an aanj lefty neck onto an rg body. A bit of profiling was required but again it worked absolutely fine.
Yes the lack of side dots does take some getting used to.
Yes it does look cool
Look here for pics:
http://moreguitarpics.fotopic.net/p28599890.html
http://steve-wright.fotopic.net/p1194238.html
nickcoumbe is offline
custom shop , custom shop guitar , fender strat , neck joint , reverse headstock , strat body , string tree , string trees
putting a jem neck on rg body *theanimal*05 Ibanez JEM, UV, JS & Other Signature Models 18 04-21-2006 11:21 AM
a guitar neck? guitardevil2005 Tech: Setup, Repairs and Mods 3 06-28-2005 11:06 PM
Wood for Guitar Neck robinson Gear, Equipment, Recording & Off Topic 1 09-14-2004 02:24 AM
mahogany neck for an electric guitar? Is this ok? SilverSurfer2 Tech: Setup, Repairs and Mods 1 05-24-2003 09:52 PM
Changing Vine inlay colors - things that make you go hmmmmmm tomizm Tech: Setup, Repairs and Mods 34 04-13-2001 03:14 PM
