Level Edge? - Jemsite
post #1 of 6 (permalink) Old 04-10-2015, 04:55 PM Thread Starter
Level Edge?
Looking for a way to make sure trem is always level.Especially since my set-up on some guitars has the knife edges below the top of the body,the usual way I set the trem is the knife edge is parallel to the top....As in pic,you can't see them so I'm looking for ideas for how to keep trem where it's supposed to be.
Superlead777 is offline
post #2 of 6 (permalink) Old 04-10-2015, 04:56 PM Thread Starter
Re: Level Edge?
No real way to judge level with knife edges below body....Any ideas?
post #3 of 6 (permalink) Old 04-10-2015, 08:46 PM
Reviews: 13
Re: Level Edge?
I may be wrong, but I think the top of the saddle should be parallel to the body. I, however, don't worry having my trems *perfectly* aligned, some minor difference is acceptable, and it won't drive me paranoid.
Rachmaninoff is offline
post #4 of 6 (permalink) Old 04-10-2015, 08:58 PM
Re: Level Edge?
If your trem is that low, I'd suggest that you need to shim the neck. You won't get full trem movement.
Takin' a Ride is offline
post #5 of 6 (permalink) Old 04-10-2015, 09:44 PM
Re: Level Edge?
I would say the one in the picture is pretty darn close... close enough for me. I agree that the top of the saddle should be flat. I can see my knife edges and they look to be parallel to the top of the saddles.
FireEagle is offline
post #6 of 6 (permalink) Old 04-10-2015, 10:41 PM
Re: Level Edge?
on each side of the tremolo wings, there is a tiny block, use that as the indicator as leveling.
the block must be level paralel to the body.
psychoshredder is offline
adjustments , edge level
I need to get to the next level RemyL Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 4 04-12-2013 03:26 PM
What can I use to block an edge pro so that it remains level? p4vl All Other Guitars (including Prestige) 15 07-24-2009 02:21 AM
cant level my edge pro cliffmmt Tech: Setup, Repairs and Mods 4 04-17-2009 04:29 PM
.11s and zero level Homebake Tech: Setup, Repairs and Mods 2 12-12-2008 10:14 PM
Lo-Pro Edge Trem Level? - Does the trem need to be level wit Dean Southcombe Tech: Setup, Repairs and Mods 5 06-11-2001 09:09 PM
