Licensed floyd rose problem in RG550EX - Jemsite
post #1 of 7 (permalink) Old 05-30-2015, 04:12 PM Thread Starter
I got a problem for a long time now with my floyd rose not being in tune.
Here's the deal:
I tune the guitar, lock the nut screws, fine tune through the fine tuners.
I pull the whammy bar backwards and release, check with my tuner and all
the strings are a bit higher, now i push the whammy bar for a dive and
release and check tuning again and now it's all back to being in tune.
If i tuned the strings after a whammy pull then when i do a dive it will
go out of tune and when i pull back it comes back to being in tune
and the reversed situation if i tuned the guitar after a whammy dive.
What can i do guys?
Thanks alot,
Roy
rg12 is offline
post #2 of 7 (permalink) Old 05-30-2015, 09:55 PM
Re: Licensed floyd rose problem in RG550EX
Assuming the one end is a lock nut, and assuming the hardware is not worn such that the strings will slide under clamp, either the strings are getting hung up on the bridge saddles (hard to tell without a pic), or the bridge posts are worn such that the bridge is not coming back to rest at the same spot.
Razzle is offline
post #3 of 7 (permalink) Old 05-30-2015, 10:14 PM Thread Starter
I don't know what you mean by hung up on the saddles and yes it's a lock nut.
I will check the bridge posts, Do you think it's possible to screw the posts
a bit in or out in order to get the side that isn't worn in front of the bridge blades?
Edit: Just read a bit about the issue on google and found out that it's mostly either the posts or
even more often the blades that needs to be sharpened or even replace the whole bridge.
rg12 is offline
post #4 of 7 (permalink) Old 05-31-2015, 09:51 PM
most likely your floyd isn't sitting in the neutral position. This is the position where the knife edges of the trem hit the trem studs at exactly at 90 degree angel(or perpendicular with relation the studs)
I recommend you pop the springs off in the back, keeping them in the same order so you can put them back in the same order, and clean both your knife edges and studs. Then put the whole thing back together.
Until you find neutral you may have some tuning issues. You'll know you have hit neutral when the tuning is stable and when you pop the bar in a flutter motion the whole body of the guitar vibrates.
j.arledge is offline
post #5 of 7 (permalink) Old 06-01-2015, 07:33 AM Thread Starter
Thanks alot i will try that as soon as i replace my strings
rg12 is offline
post #6 of 7 (permalink) Old 06-01-2015, 12:33 PM
Without seeing it for myself I won't be able to 100% identify the problem. I will agree with both Razzle & j.arledge that those are potential problem areas. Here are the things you should check.
The bridge may not be sitting fully in the neutral position. Cleaning the knife edges & studs and slight adjustments to the springs if needed will solve this. Also make sure the knife edges and studs aren't worn down. Light ware can be filed back straight if needed, if not replacement may be in order.
The sttrings may be slipping a little bit. Make sure eveything is locked down good at the locking nut and the string clamps on the saddle. Check for ware on these components also, if they are worn the strings won't be properly clamped down and will slip. If the nut is worn you'll probably have to replace it. If it's just worn clams you can replace those without replacing the whole nut. If the clamp on the saddles are worn replace them. Same thing as the nut, you can replace the clamps without having to replace the whole saddle unless the whole area is worn then the saddle may need replacing.
The strings may be catching on the saddles. Give the saddles a cleaning and check for any ware or knicks that may catch the strings. Minor knicks you may be able to file out, major ones you'll probably have to replace the saddle.
The hole the studs sit in may be ovaled a little bit due to ware and the studs are moving in it. If this is the case you'll probably need to plug the holes and redrill them.
*Quick note, anywhere I said you can file things back even this is only for very minor ware in which you just need to take out a small knick or ding that might be catching something. Don't do any major grinding on anything as that will screw up alignments then you'll may have to replace the entire bridge.
madasahatter is offline
post #7 of 7 (permalink) Old 06-01-2015, 01:39 PM Thread Starter
Thanks for summing it all up perfectly
I will replace my strings soon and remove the bridge for further investigation.
Thanks alot,
Roy
rg12 is offline
FS: Floyd Rose licensed Tremolo ThreeMan Classified Ads: Guitars and Gear 3 03-25-2012 11:52 AM
OT: question about Floyd Rose original and FR licensed 7-string tremolo Santuzzo Tech: Setup, Repairs and Mods 0 04-08-2011 02:44 PM
Floyd Rose Licensed trems at Guitarpartsdepot StevenMikel Tech: Setup, Repairs and Mods 28 06-25-2009 05:36 PM
will a Licensed floyd rose fit an OFR route? Van-Hannam Tech: Setup, Repairs and Mods 13 06-11-2007 04:21 PM
problem with licensed floyd rose slayer Tech: Setup, Repairs and Mods 6 03-17-2004 12:54 PM
