Lo Pro Edge - Bent Fine Tuner... Fixable? - Jemsite
post #1 of 4 (permalink) Old 04-04-2013, 11:01 PM Thread Starter
webmaestro's Avatar
I'm on a roll lately...
Just got a Lo Pro Edge off the 'bay for about half price. The thing is dead-mint except for one thing: the low B fine tuner is bent (see pic), and therefore will only go down a couple turns before it freezes:
I'm not sure if this happened in shipping, but I failed to ask the right questions as a buyer, but that's beside the point...
This thing is pristine--I can't find a single other thing wrong with it. It's also flat black, which is exactly the color I wanted. Is there ANY way to salvage/fix this?
webmaestro is offline
post #2 of 4 (permalink) Old 04-04-2013, 11:27 PM
IbanezFreak777's Avatar
Reviews: 25
Re: Lo Pro Edge - Bent Fine Tuner... Fixable?
If it was my problem, I would probably put the large end into a vice, heat up the screw part with a flame of sorts, and then with pliers bend it back. Or buy a replacement which shouldn't cost much..
IbanezFreak777 is offline
post #3 of 4 (permalink) Old 04-04-2013, 11:31 PM Thread Starter
webmaestro's Avatar
Are those fine tuners replaceable? That would be my preference... as I have a couple other Ibby trems lying around that I can use for parts.
How do you get that fine tuner out? I've never tried to remove one, because it seemed impossible.
post #4 of 4 (permalink) Old 04-04-2013, 11:32 PM
Plastic clip on the tip, cut it off
Rich is online
Edge 3 fine tuner out? thehungryhippo Tech: Setup, Repairs and Mods 2 07-11-2010 11:23 AM
Fine tuner problem on Edge Lo Pro Lifeson22 Tech: Setup, Repairs and Mods 9 11-10-2009 10:10 PM
Problem with low-E fine tuner on Edge trem stratoskier Tech: Setup, Repairs and Mods 5 12-28-2007 05:18 PM
edge pro fine tuner problem arnab Tech: Setup, Repairs and Mods 23 08-31-2007 04:45 AM
limited range on fine tuner (edge trem) lemongrass Tech: Setup, Repairs and Mods 4 03-20-2004 07:51 AM
