Lo Pro Edge into Ibanez S370 Body? - Jemsite
post #1 of 8 (permalink) Old 08-08-2004, 10:10 AM Thread Starter
Does anyone know if you can fit the Lo Pro Edge trem into an S370 body - the body originally had a Lo TRS II installed.
jemotwc is offline
post #2 of 8 (permalink) Old 08-09-2004, 01:25 AM
You can with some mods it's eaiser to put in an original floyd that's what i'm lpanning on doing to my S371QS and no mods so the jobs a lot easier
Fatal-Tragedy is offline
post #3 of 8 (permalink) Old 08-09-2004, 03:28 AM Thread Starter
Is that the same for an S470 too, or is that different?
jemotwc is offline
post #4 of 8 (permalink) Old 08-31-2004, 09:05 AM
Same thing with the (older) S470, as those have the TRS.
rory is offline
post #5 of 8 (permalink) Old 08-31-2004, 11:56 AM
Click the LGM guitars banner at the top. Jeremy does the TRS to Edge route for 25$. Then just snag a lo pro from rich. (Click the Ibanez Rules banner for rich's site.)
Kontalonis is offline
post #6 of 8 (permalink) Old 08-31-2004, 01:01 PM Thread Starter
The reason I ask is that lots of people say you can't but I have checked ALL the dimensions, and it looks like it shouldn't be a problem at all. Am I missing something here?
jemotwc is offline
post #7 of 8 (permalink) Old 08-31-2004, 01:23 PM
To retrofit an Edge/LoPro in a TRS/OFR guitar:
The Edge/LoProEdge will not directly swap into your Ibanez (or other guitar) with a TRS/TRS-II/OFR. A few modifications will typically be required
Tremolo Routing Changes - You will need to increase the length of the cavity (in front of the posts and behind the fine tuners), you might have to widen the cavity and you will have to rout the cavity deeper for full pull-up.
Tremolo Posts - All these locking trems have the same post-to-post measurements. However, the Edge equipped guitars have body anchors that accept the Edge posts which use a set-screw to further stabilize the post to the body anchor. This is a major improvement and something the TRS/OFR guitars lack. It keeps the post from wobbling or moving in the body anchor. The Edge posts do not fit the TRS body anchors. In order to install the improved Edge posts in your TRS equipped guitar, the TRS body anchors will have to be REMOVED (drilled out typically) and replaced with the Edge anchors (glued into the body) before you can use the Edge post with locking set screw.
Best Choice Option - If you have a TRS/TRS-II equipped Ibanez guitar, you can install the Floyd Rose Original/Pro without any modifications to your guitar. That is the easiest and best alternate.
post #8 of 8 (permalink) Old 08-31-2004, 01:57 PM
Although, I'm thinking that they may not route the TRS cavities uniformly, as I've heard one or two people on the board here say they were able to do it with no routing.
The Edge Pro/Edge Pro II should be a different story, however, as I believe the trem studs fall at diffrent places, and you'll SERIOUSLY throw off the intonation.
-D
Drew is offline
edge trem , equipped guitar , floyd rose , lgm guitars , locking trems , pro edge , pro edge trem , trem studs
Ibanez jem 555 replacement body plus edge pro 2 jsdisciple Classified Ads: Ibanez JEM/UV Guitars 8 06-21-2011 04:56 PM
Ibanez 550 maple neck, Edge trem, body, etc... Severinsteelsmith Classified Ads: Guitars and Gear 10 01-14-2011 05:44 PM
Ibanez S370, which pickup for neck? AfonsoServulo Pickups & wiring 1 01-26-2010 02:52 PM
mahogany body for Ibanez edge floyd roses? SilverSurfer2 Tech: Setup, Repairs and Mods 2 05-11-2003 10:19 PM
Ibanez body, edge or lopro - question for ya... davenit Ibanez JEM, UV, JS & Other Signature Models 11 04-20-2001 10:22 PM
