Lo Pro Edge Intonation - Jemsite
post #1 of 5 (permalink) Old 12-17-2005, 09:08 AM Thread Starter
Unhappy Lo Pro Edge Intonation
Hi, I've been setting up my RG 550 LTD PT and the only way I can get the intonation correct is to move the low e saddle quite far back, further than my other lo pro edge equipped guitars. This seems unusual, but its the only way I can get it right. Any ideas or suggestions?
Ant1981 is offline
post #2 of 5 (permalink) Old 12-17-2005, 09:30 AM
Re: Lo Pro Edge Intonation
If the intonation is right then there's nothign wrong with it.
Cozi101 is offline
post #3 of 5 (permalink) Old 12-17-2005, 11:02 AM
Are you intonating your guitar with a brand new set of strings?? Also, check to see if your pickups are too high and if they're causing too much string pull. I've had strange problems like that before and it took forever to figure out.
(What's even stranger is that I've had guitars intonate perfectly at two different points at the extreme opposite of each other!! Excessing magnet pull can puts your intonation to $#!T sometimes)
buddroyce is offline
post #4 of 5 (permalink) Old 12-17-2005, 01:23 PM
Thumbs up Re: Lo Pro Edge Intonation
They both have good points, make sure you check every possibility; to be honest, Buddroyce seems to have experience, try to get it as close to your other guitars as possible without losing correct innotation, this will give you a more comfortable and familiar playing experience
PacificaJonny is offline
post #5 of 5 (permalink) Old 12-17-2005, 07:24 PM Thread Starter
Yea I'm using new fresh strings, and I at first tried to match another lo pro edge guitar. I guess even if the saddles are in different positions from another guitar, it doest matter so much if the intonation is right i guess it just looks different. I'll check the pickups too though.
Ant1981 is offline
equipped guitar , pro edge
Intonation on Edge Pro mizukster777 Tech: Setup, Repairs and Mods 6 01-05-2011 11:43 PM
Edge III intonation Floating_Guy Tech: Setup, Repairs and Mods 1 06-25-2010 03:40 PM
Edge Intonation Tool... chaos731 Tech: Setup, Repairs and Mods 9 05-19-2008 05:56 PM
Intonation tool for Edge and Lo-Pro? choubix Tech: Setup, Repairs and Mods 17 06-13-2007 11:48 PM
WTB: Edge Intonation tool GLG421 Classified Ads: Guitars and Gear 6 05-05-2005 08:58 PM
