Re: lo pro edge tremolo might be warn and is it making my guitar go out of tune?
yeah rich i have followed word for word every step i can find on your site when setting up my guitar before i even posted it your site has been very helpful and my main reference. every issue i have hit i found an answer there so thanks. and so far with everything it has all worked like a charm. maybe im just not as good at this like a notorious pro like you are rich but i did follow all that when tuning and all. and when i dont use the tremolo it stays in tune for days and probably could go for a whole month if i never used the tremolo but. its my tremolo that throws it out a bit after a while. you did say no one gets 1000% return but does mine sound like its still not up to par with what it should be doing rich? after using it for like an hour or two if i really use the tremolo a lot it will go out like 24 cents sharp or flat. i feal i need new poles probably i was planning on ordering them from you soon. does that sound like most likely my issue or what else should i check or consider replacing or checking out to fix too? or is this acceptable for a floating tremolo?
thanks rich.
