Lo-Pro and Original Edge - Jemsite
post #1 of 5 (permalink) Old 02-13-2006, 03:12 AM Thread Starter
If I buy a body that was routed for a Lo-Pro, can I put an Original Edge in it? The dimensions are basically the same, and I won't have to do any additional routing, correct?
Thanks.
MrChadley is offline
post #2 of 5 (permalink) Old 02-13-2006, 06:44 PM
Re: Lo-Pro and Original Edge
It should fit fine, but you may bottom out when pulling up (in which case you would need a deeper route in the back).
ryanb is offline
post #3 of 5 (permalink) Old 07-11-2006, 12:52 AM
Original edge to lopro is a drop in replacement. lopro to original will require a little routing as the recess is slightly longer for the original edge due to the long allen screws sticking out. I have both style bodies in front of me and measure about 3/16" difference.
albee1952 is offline
post #4 of 5 (permalink) Old 07-11-2006, 03:31 AM
ive never seen them require routing their location in the routes are slightly different. having done this myself it only limits full pullup range.
sniperfrommars1 is offline
post #5 of 5 (permalink) Old 07-11-2006, 05:54 AM
dex
Albee is correct - guitars routed for Lo-pro will not be routed enough to allow for the sticking bolts at the back.
Check the side by side photos for reference - clearly visible on the UV routed for Edge7 with a lo-pro7 in it there's a lot more room at the back.
http://www.jemsite.com/jem/trems.htm
ilia
dex is offline
xiphos with edge pro trem and original edge studs/anchors ibanguitar All Other Guitars (including Prestige) 2 10-15-2013 10:45 PM
original edge or lo-pro edge on ibanez rg350 saeed-satriani Tech: Setup, Repairs and Mods 4 12-11-2009 01:56 PM
WTT: Black Original Japanese Edge > Chrome Original Japanese Edge lewis.mann Classified Ads: Guitars and Gear 0 11-23-2008 04:03 PM
WTB: Edge Pro Tremolo or Trade for mint Original Edge For_The_Love_Of_Jems Classified Ads: Guitars and Gear 3 02-12-2008 01:24 AM
Replacing Lo-Pro Edge trems with original Edge? Max-T Tech: Setup, Repairs and Mods 1 09-06-2004 07:54 AM
