lo-pro springs configuration - Jemsite
post #1 of 13 (permalink) Old 09-12-2004, 05:25 AM Thread Starter
Maybe for the next restringing I'll put a 060 as low B on my rg2027, and so I'll need more spring tension, but the two screws of the spring claw have run out (I can't turn them anymore into the wood!). Now I have 3 springs in the standard position: | | |
Do I need another spring? Or should I try this configuration: / | \ ?
Do this last add tension in respect of | | | configuration?
Thanks!
Pesso is offline
post #2 of 13 (permalink) Old 09-12-2004, 12:17 PM
if you're going from a 52 to 60 changing from | | | to / | \ should be enough...but man, i would never drill all the way into the wood...i think you should consider some new springs regardless
bobojem is offline
post #3 of 13 (permalink) Old 09-12-2004, 01:52 PM Thread Starter
Uhm...why? My local music shop tech told me that there is nothing wrong with it....
Pesso is offline
post #4 of 13 (permalink) Old 09-12-2004, 02:04 PM
oh its just a personal preference. I don't like going to the extreme in anything; plus I always like to leave myself some room to go either way.
bobojem is offline
post #5 of 13 (permalink) Old 09-12-2004, 07:46 PM Thread Starter
I see. So there's nothing wrong with it in term of harming the guitar? I seem to recall that Rich once told me that it's okay...
Pesso is offline
post #6 of 13 (permalink) Old 09-12-2004, 07:53 PM
Nothing wrong with arrow config.
If you just can't screw in anymore then drill the holes a little deeper. Fresh mahogany is very tough to screw into. If you're just plain out of room either go arrow, add more springs, or use stiffer springs.
Rich is offline
post #7 of 13 (permalink) Old 09-13-2004, 04:59 AM Thread Starter
It's not that I "can't screw anymore" because the wood is tough, it's that the screws have run out: the screw heads are touching the wood, it's physically impossible to screw in them more!
Ok, so maybe I'll try another configuration!
Sorry to be so anal but, is there something wrong in having the springs claw screws all into the wood?
Pesso is offline
post #8 of 13 (permalink) Old 09-14-2004, 01:46 PM Thread Starter
Bump!
Pesso is offline
post #9 of 13 (permalink) Old 09-14-2004, 09:51 PM
Only than you have no room for adjustment, no.
Rich is offline
post #10 of 13 (permalink) Old 09-15-2004, 04:10 AM Thread Starter
Ok, thanks! I'll put them in arrow if I need more tension. Thanks Rich!
Pesso is offline
post #11 of 13 (permalink) Old 10-11-2004, 06:47 AM
Excuse my ignorance, whats the difference in terms of playability between the lll and /l\ configuration on a regular 6 string tuned in standard tuning ?
Benson is offline
post #12 of 13 (permalink) Old 10-11-2004, 10:30 AM
no differences that could be felt by human being. only Eric Johnson will.
nuno is offline
post #13 of 13 (permalink) Old 10-11-2004, 10:24 PM
Actually, I find the action of the trem is quite noticably stiffer when using arrow configuration as compared to the same guitar, same string gauge, just re-setting to go from straight to arrow configuration. I much prefer the springs parallel.
... and I'm no EJ... =]
steve is offline
claw screws , eric johnson , local music shop
Original Edge Trem & 3 springs vs 4 springs doriangrey Tech: Setup, Repairs and Mods 6 09-17-2010 01:38 PM
Pickup configuration Ring0 Pickups & wiring 0 06-30-2006 12:00 AM
JS Control Configuration DaveP Ibanez JEM, UV, JS & Other Signature Models 6 03-09-2006 05:57 PM
Your fav. pickup configuration Pee Polls 54 07-17-2005 06:37 PM
Has anyone ever tried a H-H-H pup configuration on a JEM? Courjan Ibanez JEM, UV, JS & Other Signature Models 10 08-08-2002 03:31 PM
