lo pro trem arm replacement PLEASE HELP! - Jemsite
post #1 of 2 (permalink) Old 08-09-2004, 06:08 PM Thread Starter
Hi I looked and looked and it may be out there, but I couldn't find it....
HOW does one pop out that piece of the lo pro trem to replace the bar? I have a lo pro that allows the bar to go all the way down in
this is the bar I have to fit the lo pro above it's in an RG550
Please help....is this bar supposed to "STOP" at some point, or continue to "bottom out"?....please help! Thanks
muddeone is offline
post #2 of 2 (permalink) Old 08-09-2004, 08:42 PM Thread Starter
found what I needed over at ibanezrules.com
Loose Arm Holder
Tightening the arm holder is best done with the trem removed from the guitar. Hold the trem in your hand and use a set of channel lock pliers to tighten the holder from the bottom side. Only grab the END of the arm holder with the pliers because if you use them anywhere else on the holder you'll deform the holder and the bar will not fit in it anymore. I normally don't remove the bar retaining spring but be aware if you spin over it with the pliers you'll be ordering a new spring. Once you have the holder itself tight take a 10mm wrench and while keeping counterclockwise tension on the holder with the pliers, tighten the holder nut [if you try to tighten the nut without keeping the tension on the holder the holder will loosen again] This might be a little tricky for some who could make good use of a vise to hold the trem while tightening the nut. Put the trem block in the vise to hold. You will find some later model Lo Pro Edge trem where it's impossible to get the nut tight without loosening the holder [I have yet to get to the bottom of this] and in this case it's more important to have the holder tight than the nut tight, so tighten with the pliers as tight as you can possibly get it [remember, only use the pliers at the tip of the holder!!]. Of course there is a tool they use to tighten the holder at the factory from the top and why the holder has a slot cut in the top, but the tool is not available anywhere [even from the factory]. Some people will use a large screwdriver and tighten the holder from the top, but you have a very great chance of slipping out of the slot and making a major scratch, and, you will not get the holder near as tight as you will using channel lock pliers at the tip of the holder. I have found that a holder tightened this way is tight for good, but some of you may want to go the extra step and use Locktite on the holder threads before tightening. Locktite is available at most auto parts stores and is used in engines to keep bolts from loosening under constant vibration. More or less, it glues the threads together, but not so glued it can't be pulled apart again later....
http://www.ibanezrules.com/tech/setup/loose_holder.htm
muddeone is offline
arm holder , edge trem , pro edge , pro edge trem , trem block
Question for ZR trem experts // replacement trem arm dariusvara Tech: Setup, Repairs and Mods 2 07-09-2010 01:50 AM
Replacement trem bar foolboy Tech: Setup, Repairs and Mods 4 01-31-2010 05:25 PM
Trem replacement. Gio-42 Tech: Setup, Repairs and Mods 1 09-29-2009 04:48 PM
Replacement Trem DannyB819 All Other Guitars (including Prestige) 1 03-02-2009 04:25 PM
replacement trem thc303 Tech: Setup, Repairs and Mods 7 03-05-2003 04:20 PM
