Lo TRS II -> Gotoh GE1996T block height - Jemsite
post #1 of 7 (permalink) Old 05-13-2019, 03:01 AM Thread Starter
Hi all,
I have an old 1996 RG450DX with a Lo TRS II trem. I am thinking about replacing it with the Gotoh version. I have no experience modifying a guitar so most likely I may get a local guitar tech to do the swap for me since I read it requires rerouting to use the new studs, but I need to get the one with the correct block height. The Lo TRS II block height is 35mm, but the Gotoh's available at 40mm, 36mm, and 33mm. Should I get the 36mm block?
Thanks,
Tang
tanglai is offline
post #2 of 7 (permalink) Old 05-13-2019, 08:00 AM
You could play it safe & go with the 33, or take the chance & go with the 36 sine there is only 1 mm difference.
snaggleyoda is offline
post #3 of 7 (permalink) Old 05-13-2019, 09:34 PM
Reviews: 120
Re: Lo TRS II -> Gotoh GE1996T block height
At any rate you can always leave the back cavity cover off anyway. But I thought the block length was 32mm
LonePhantom is online
post #4 of 7 (permalink) Old 05-14-2019, 05:47 PM
The measurement refers to the height. For example my 86 Roadstar 2 with non recessed trem has a much greater sustain block height than my rg520 also with edge but is recessed is much shorter. Obviously the width is the same as they are the same trem, just installed differently.
post #5 of 7 (permalink) Old 05-14-2019, 09:20 PM
Reviews: 120
Sorry I meant height
post #6 of 7 (permalink) Old 05-15-2019, 07:47 AM
I have one In my js100.. needed to work on the trem cavity ... shortened the tremblock.. new holes for the tremposts
Marcel-JS-build is offline
post #7 of 7 (permalink) Old 05-22-2019, 07:37 AM
The measurement refers to the height. For example my 86 Roadstar 2 with non recessed trem has a much greater sustain block height than my rg520 also with edge but is recessed is much shorter. Obviously the width is the same as they are the same trem,Dafont Showbox Adam4adam just installed differently.
it is clear that he means height and nothing else
klimbo is offline
lo trs ii
Ibanez RG370 + Gotoh GE1996T sebachl Tech: Setup, Repairs and Mods 0 02-23-2015 01:08 PM
Install tips for Gotoh Floyd Rose ge1996t ? plugger Tech: Setup, Repairs and Mods 6 07-22-2008 06:59 PM
Gotoh Licensed Floyd (GE1996T) neptoess Tech: Setup, Repairs and Mods 1 05-23-2007 08:14 PM
Id VH Plays in 07- Heeeeeere's Davy from Last Summer>>>>> jemaholic Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 6 01-09-2007 04:50 AM
got my 2550egk and all i can say is>>>>>>>> jukes All Other Guitars (including Prestige) 10 03-04-2006 12:46 AM
