Locking nut doesn't lock! - Jemsite
post #1 of 16 (permalink) Old 09-17-2015, 05:18 AM Thread Starter
This is really odd, bought a nice secondhand RG550 and noticed I couldn't lock the E/A nut clamp it started to tighten then would go loose again.
Me thinks knackered thread in the nut...anyhoo noticed the other 2 clams could be tightened BUT the machine heads could alter the string tuning when clamped (??)
Never seen a clamped top nut that allows the machine heads to alter the tuning - very strange.
So I bought a replacement nut, fitted it and now I can lock all 3 clamps at the nut but the machine heads still can alter the tuning no matter how tight the clamps are locked!!
Never experienced this before, on the JEM the machine heads make no difference once the nut clamps are locked but on this RG550 even a new top nut assembly doesn't stop the machine heads altering the tuning.
Why is this, can/does it need to be fixed and if I use the trem does that mean the tuning will be out??
GuitarAkuma is offline
post #2 of 16 (permalink) Old 09-17-2015, 05:33 AM
Re: Locking nut doesn't lock!
Did does not make sense. If the strings can move under the pads, then the pads are far from locked. This or you bought a totally different design.
If I were you, I would try to fix the original nut. Take it to a machine shop who can do M4 heli-coil. That's all you need really, to fix the low/ (bass side) thread on the original nut.
panix is offline
post #3 of 16 (permalink) Old 09-17-2015, 05:39 AM Thread Starter
exaclty but on the original nut the other strings could be adjusted by the machine heads when clamped as well, and I do mean clamped to the point of risking stripping the thread in the nut!
post #4 of 16 (permalink) Old 09-17-2015, 06:53 AM
Hmmm, in this case grooves had been developed either on the nut's top or the bottom of the pads.
The newer one does exactly the same?
panix is offline
post #5 of 16 (permalink) Old 09-17-2015, 07:09 AM Thread Starter
yes the brand new nut does exactly the same thing!
I tried interchanging the new clamps with the old ones and no difference, extremely weird...
post #6 of 16 (permalink) Old 09-17-2015, 07:16 AM
Are you sure you are not doing anything wrong? The torque applied should be as if you were turning the alen with one finger.
panix is offline
post #7 of 16 (permalink) Old 09-17-2015, 07:22 AM Thread Starter
it doesn't matter how it is tightened, gently until the resistance is felt or until it doesn't turn anymore the string still slip in the nut, something which seems against the laws of physics!
Tried turning the clamps round as well and using the clamps off the old nut no difference!
post #8 of 16 (permalink) Old 09-17-2015, 08:24 AM
There is like a straight line on the top of the pad (clamp). This should be parallel to the strings.
panix is offline
post #9 of 16 (permalink) Old 09-17-2015, 09:01 AM Thread Starter
done that and rotated them 180 degrees still locks nothing!
post #10 of 16 (permalink) Old 09-17-2015, 09:55 AM
then 90 degrees
panix is offline
post #11 of 16 (permalink) Old 09-17-2015, 11:15 AM
This literally doesn't make any sense.
Maybe you can post a picture? Both of the nut "locked" and the underside of the string pads?
Drew is offline
post #12 of 16 (permalink) Old 09-17-2015, 04:00 PM
Is the nut mounted from the back? If it is, are the allen bolts coming too far through the nut and stopping the pads sitting flush, had this on a lot of EVH's.
andyt is offline
post #13 of 16 (permalink) Old 09-18-2015, 12:45 AM
the OP said it is a top mounted nut, or so he implied.
panix is offline
post #14 of 16 (permalink) Old 09-18-2015, 07:11 AM Thread Starter
it is screwed into the neck from the top not the bottom as on my lovely 777VDY!
Really does defy logic, maybe the guitar is cursed?
post #15 of 16 (permalink) Old 09-18-2015, 12:51 PM
Yeah i think getting a priest is one of the steps of Ibanezrules tech section.
Rafafas is offline
edge , floyd , ibanez , locking , tuning
why doesn't ibby make a trem with a lock on it? windycitycane All Other Guitars (including Prestige) 3 01-26-2014 12:37 PM
locking nut lock bolt loran333 Tech: Setup, Repairs and Mods 6 10-21-2009 11:47 PM
Locking stud lock diameter? jim777 Tech: Setup, Repairs and Mods 6 06-02-2007 02:15 PM
Notes detuning the moment i lock the locking nuts..pls help.. kelvin55 Tech: Setup, Repairs and Mods 9 12-25-2005 07:39 AM
I lost one of the locking nut lock screws from my RG HELP!!! Aussie_520QS Tech: Setup, Repairs and Mods 0 07-13-2002 03:44 AM
