Locking nut neck on fixed trem body. - Jemsite
post #1 of 7 (permalink) Old 03-13-2016, 11:36 PM Thread Starter
Has anyone ever put a neck with a locking nut on a body that had a fixed trem or string thru body? I'm wondering if it effects the intonation or anything else for that matter.
I've always wanted to take my RGA and put a maple boarded JEM or really nice maple boarded prestige neck on it. The only problem; 99.9% of those necks have locking nuts. It would be easier to get a custom neck made, but I'd like to see if it's doable with a real Ibanez neck before I consider those options
vultures is offline
post #2 of 7 (permalink) Old 03-14-2016, 03:21 AM
Super Moderator
Re: Locking nut neck on fixed trem body.
Yep it's fine as long as the necks in question have the same neck joints.
jono is offline
post #3 of 7 (permalink) Old 03-14-2016, 03:35 AM
I saw a bolt on conversion nut to regular nut somewhere in the last few years, I only paid enough attention to notice but it does exist.
Rich is offline
post #4 of 7 (permalink) Old 03-14-2016, 08:54 AM
It would be impossible to tune. Locking the nut will pull the guitar out of tune and you'd be screwed with no fine tuners. Locking nuts also don't function great unlocked. Way too much friction which means tuning stability would suffer.
It probably wouldn't be extremely hard to get someone to make a small block of maple of something to glue in there and then cut it for a standard nut.
Takin' a Ride is offline
post #5 of 7 (permalink) Old 03-14-2016, 05:18 PM
If you don't like absolutely perfect intonation exactly all of the time, adjusting the intonation even a miniscule bit on a guitar with a locking nut causes quite a bit change in string tension, so if you're using a strat style bridge that has screw adjust intonation, or something similar, you could use that as a (slightly) quicker method of tuning rather than unlocking the locking nut.
Roachy is offline
post #6 of 7 (permalink) Old 03-14-2016, 08:32 PM Thread Starter
What if I wouldn't lock it down or use one of those conversion nuts? Maybe just a set of locking tuners, but otherwise leaving the locking/clamp down part completely off the neck itself?
vultures is offline
post #7 of 7 (permalink) Old 03-14-2016, 10:19 PM
It's about more than just the locking tuners. A locking nut is meant to be locked down. That's where you get the great tuning stability from. With the nut unlocked, you will get all sorts of friction from the nut and string tree and the tuning stability would go to hell.
My $0.02
WTB: Hardtail Fixed Bridge Guitar Body for 24 Fret Neck t1r12003 Classified Ads: Guitars and Gear 3 06-24-2009 06:11 PM
WTB Ibanez Cosmo Edge Pro Trem, Tuners, Top Locking Nuts & Neck Screws rangers158 Classified Ads: Guitars and Gear 0 12-01-2008 04:39 AM
Want fixed bridged body for my RG 550 with all acceess neck joint! DotNetTim Classified Ads: Guitars and Gear 0 05-30-2005 04:46 AM
RG fixed bridge?!?!? - I know You're "*the* locking trem com jono Comments to Ibanez 7 07-20-2001 09:28 PM
Sperzel locking tuners & non-locking nut - for a fixed bridg jemsite Tech: Setup, Repairs and Mods 9 03-22-2001 10:51 PM
