Locking nut options - Jemsite
post #1 of 5 (permalink) Old 11-29-2018, 01:59 PM Thread Starter
Locking nut options
Hi,
I got a used guitar a while ago and I'm having problems with the locking nut. It has a kahler set up so it has the traditional nut combined with a flip lock nut. I've posted a picture below.
The problem is that no matter what I've tried the guitar will not hold tune for very long. I've heard that the locking nut behind traditional nut isn't so great, is that true?
I was thinking of doing away with both and fitting a floyd rose style locking nut. It would require some work but I'm ok with that.
Would that be a better more stable option?
Cheers,
Pete
peter762033 is offline
post #2 of 5 (permalink) Old 11-29-2018, 02:19 PM
Those Kahler flip lock nuts are junk, you'd be better off fitting locking tuners or converting the flip lock to allen bolts, fitting a Floyd nut will be more work but will perform the best.
sepulchrave is offline
post #3 of 5 (permalink) Old 11-29-2018, 03:40 PM Thread Starter
Re: Locking nut options
Thanks for your reply sepulchrave. Yep it seems like a pretty odd design, not sure how they expected it to clamp the stings properly!
Do you think an Allen bolt version in conjunction with a Graphtec nut would be as good as the Floyd type?
Cheers,
Pete
post #4 of 5 (permalink) Old 11-29-2018, 04:03 PM
You don't even need the Graphtech nut, just lube the existing nut and it'll work just fine.
post #5 of 5 (permalink) Old 12-04-2018, 11:08 AM Thread Starter
Cheers, I'll get the Allen bolt string lock ordered, lube the nut and hopefully that will solve the problem!
Thanks for your input,
Pete
FS: Ibanez/Gotoh Chrome Locking Nut & Magnum Locking Machine Heads Japanese JEM Or RG lewis.mann Classified Ads: Guitars and Gear 1 05-15-2009 03:06 AM
ZR tremolo with locking tuners, no locking nut? sgian Tech: Setup, Repairs and Mods 1 06-01-2007 07:35 AM
Locking Nut vs. Locking Tuners ryanb Tech: Setup, Repairs and Mods 11 03-30-2006 12:03 AM
Modding a Non-Locking neck to fit a Locking nut? ZOMB13 Tech: Setup, Repairs and Mods 21 07-04-2005 07:11 PM
Sperzel locking tuners & non-locking nut - for a fixed bridg jemsite Tech: Setup, Repairs and Mods 9 03-22-2001 11:51 PM
