Locking nut replacement Universe777bk - Jemsite
post #1 of 9 (permalink) Old 03-10-2017, 10:31 AM Thread Starter
Hey guys,
I have been bothered by a sitar like rattling noise when playing the open high B and sometimes G string.
Shimming the nut and replacing strings didnīt help at all and there seems to be plenty of space between the strings and frets.
Looking at the nut, I have noticed some worn in groves that must have developed over the course of 10 years.
I live in Germany and tried to find a replacement for the locking nut but it seems to be quite a bit more difficult than I hoped.
Meinl (German distributor for Ibanez) doesnīt seem to have it in stock and wants to order one for over 100€!
There are some other locking nuts for 7 String Ibanez guitars and I wondered if they might work just as well? I just donīt see why I should pay well over 100 bucks when there are other Ibanez locking nuts that may work just as well for under 75€ or so.
My Ibanez Universe is a 2006 Model and thus should have the UV Prestige Neck.
I have looked up its specs on the Ibanez Wikia but I am not allowed to post links since I donīt have 5 posts on the forum yet -_-
Would it be possible to look for another current production model neck with identical specs and just buy its locking nut instead?
Jackoclock is offline
post #2 of 9 (permalink) Old 03-10-2017, 02:44 PM
Re: Locking nut replacement Universe777bk
That's a bottom mount, right? I don't see why you couldn't use one from an RG7620, very common model.
JSibanez is offline
post #3 of 9 (permalink) Old 03-10-2017, 03:16 PM Thread Starter
Yes, the screw heads can be seen on the back of the neck/headstock.
The regular RG7 Neck (the one which can be found in said RG7620) has different dimensions than the UV Prestige Neck.
The RG7 J Custom however, seems to have the same Specs as the UV Prestige Necks...
Does no one have any experience with this?
post #4 of 9 (permalink) Old 03-10-2017, 03:22 PM
The RG7620 uses the same bridge as the Universe so the radius should be the same. Sure the neck profile might be different but I would think the nut is the same.
Have patience regarding other responses, it's only been a few hours since your first post.
JSibanez is offline
post #5 of 9 (permalink) Old 03-10-2017, 03:54 PM
webmaestro's Avatar
Did you try pulling the string to one side of the string slot (in the nut) as you locked-down the pressure pad? Try that. So, to try and describe this...
Just before you lock down the pad, gently put a little pressure on one side of the string to push it in that direction of the string groove. Hold that position and lock the pressure pad down. Is the buzz gone?
If not, loosen the pressure pad and do the exact same thing, but push the string toward the OTHER side of the string slot. Hold it, lock the pad down.
If neither works and your string still buzzes, then proceed with looking for a new nut.
webmaestro is offline
post #6 of 9 (permalink) Old 03-10-2017, 04:36 PM
All current thru mount 7 nuts are over $100.
To rule out the nut push down on the string with a pick right as it breaks off the nut. If it goes away it's the nut. Try Webs answer.
Rich is offline
post #7 of 9 (permalink) Old 03-10-2017, 04:43 PM Thread Starter
Thanks for all the ideas!
I have done this with my pick and fingernail in the past. The buzzing disappears.
So I will have to look into a new nut...
I was experimenting with aluminium foil by putting tiny pieces between the string and the nut itself to create some sort of "padding". That kind of helped for a while but ended up being only a temporary fix.
post #8 of 9 (permalink) Old 03-10-2017, 06:35 PM
webmaestro's Avatar
Speaking of aluminum foil...
Something else that's worked for me in the past is using skinny strips of aluminum foil to actually alter the front-to-back angle of the nut. So, if you can imagine this: I actually shimmed just the front side of the nut (where the strings enter the fretboard) with thin strips of aluminum foil.
Now, this particular nut is tilted slightly backwards. I just kept stacking foil until the buzz stopped. Won't work for every case, but thank god it worked in this one. Finding a replacement nut was impossible at the time.
post #9 of 9 (permalink) Old 03-17-2017, 05:06 AM
try to coat the area where the strings sits with a thin layer of "metal" epoxy glue. Make a new groove if needed.
xinap is offline
locking nut , replace , universe
Locking nut replacement xavgo2 Tech: Setup, Repairs and Mods 2 01-01-2011 07:31 PM
Replacement locking nut guitargoob Tech: Setup, Repairs and Mods 1 08-08-2006 03:16 PM
Locking nut size/replacement The Shred Baron All Other Guitars (including Prestige) 3 12-30-2005 02:12 AM
Locking Nut Replacement StevieHongKong Ibanez JEM, UV, JS & Other Signature Models 5 07-21-2004 09:55 PM
locking nut replacement harborcitymadman Tech: Setup, Repairs and Mods 3 05-09-2004 12:02 AM
