lopro edge not working with me - Jemsite
post #1 of 6 (permalink) Old 02-21-2004, 11:22 PM Thread Starter
I just restrung my UV777. I stayed true with the methods I've known: one string at a time..tune to neighboring string....stretch...retune...stretch and retune...lather rinse repeat. But the problem I'm experiencing is that my bridge doesn't seem to want to set like it did when I first got it (twas set up at the shop) and the bridge angle clearly isn't like it is in the 'bridge floating tremolo angle" article. It's definetly raised above the neutral point. I did try tightening and loosening the claw screws but that seems to change nothing if anything. Getting confused so I don't want to do anymore untill I have som guidence. I know it's not right because the bar, when faced towards the headstock, manages to bump into the selector switch when put in to neck position.
Help!!!
xaoscontrol is offline
post #2 of 6 (permalink) Old 02-21-2004, 11:26 PM
Turn both claw springs a half turn in. Retune. Recheck angle. Rinse, Repeat. [1/4 turn is a large amount for a claw adjustment and the strings will definately feel it.]
http://www.ibanezrules.com/tech/setup/angle.htm
Rich is offline
post #3 of 6 (permalink) Old 02-22-2004, 12:28 AM Thread Starter
Thanks Rich!!
realizing that I put a set of 10s on my UV (when I bought the UV, I bought an extra set of strings and they didn't have 9s). So, I jacked another tension spring from my decomissioned S540 and that helped a great deal. I thinnk the trem level is now more into the body cavity but I'm okay with that. I'm sure a professional set up will help, but at long as it plays n' stays, i'm good.
Thanks again
post #4 of 6 (permalink) Old 02-22-2004, 12:48 AM
It only takes a little knowledge and a little time to do everything yourself
Rich is offline
post #5 of 6 (permalink) Old 02-22-2004, 06:27 AM
Rich, This strikes me as possibly one of the most obvious yet invaluble piece'sof advice i have ever read or heard
xaos, Glad it's all working well again, Keep up the 7 string thrashing
Rob
Jem7RB MK is offline
post #6 of 6 (permalink) Old 02-22-2004, 10:54 AM Thread Starter
Agreed. Been so long before I did an maintaining on my own axe and I feel kind of funny working on this one. It's as if I driven a 73 mustang forever and just got the 2005 Ford GT. I was wondering if aquiring some broken in springs will not only help raise the trem level but allow the claw adjustment screws to actually effect the the trem as well. Adjusting them the other night didn't seem to effect the physical appearence of the trem, only the audible change of the trings going up or down a 1/2 step or so.
bridge angle , claw screws , floating tremolo , neck position , tremolo angle
WTB: square heel neck and edge/lopro edge needed nafigator Classified Ads: Guitars and Gear 0 03-27-2011 05:41 PM
FS/FT Gold LoPro Lo-Pro Lo Pro Edge for original Edge mechanyx Classified Ads: Guitars and Gear 12 12-23-2010 03:25 AM
Replacing Edge/LoPro Edge with a ZR tremolo? ZOMB13 Tech: Setup, Repairs and Mods 8 06-04-2009 12:00 PM
Can you replace an edge trem with a LoPro Edge? - Is it poss Cycovision Tech: Setup, Repairs and Mods 7 05-16-2009 12:22 AM
Feel of LoPro Edge 7 vs LoPro Edge 6 and other setup issues mdrobnak_rg7 Tech: Setup, Repairs and Mods 9 04-16-2003 02:56 PM
