LoPro Help!! - Jemsite
post #1 of 7 (permalink) Old 12-27-2005, 11:10 AM Thread Starter
LoPro Help!!
I've got an Ibanez Jem7DBK. I foolishly cut the strings without releasing the tension and the bridge has snapped back and has "sunk" into the body and when I push the trem bar down it kind of moves forwards and "klinks".
What's happened and how do I fix it?
sihackett29 is offline
post #2 of 7 (permalink) Old 12-27-2005, 11:30 AM
Re: LoPro Help!!
put strings on.
damo7v is offline
post #3 of 7 (permalink) Old 12-27-2005, 11:43 AM
Re: LoPro Help!!
Yes. Make sure the knife edges are in the post grooves, and string it up. You should be fine.
ryanb is offline
post #4 of 7 (permalink) Old 12-27-2005, 12:00 PM
Re: LoPro Help!!
it will klink as the knife edges are making contact with the v groove in the posts, put a block bedind the trem so that the float level is good, then string it back up and you should be fine.
Ant1981 is offline
post #5 of 7 (permalink) Old 12-27-2005, 12:06 PM Thread Starter
Re: LoPro Help!!
I've tried that. Pt some strings on it and when I depress the bar the bridge leaps out of the bridge-cutaway and is on a ridiculous angle to the body
post #6 of 7 (permalink) Old 12-27-2005, 12:14 PM
Re: LoPro Help!!
Have you changed string gauge? Have you altered the spring tention at the back of the guitar? Best to double check the bridges knife edges are in good contact with the v groove of the trem posts. Make sure the posts are locked if possible. Also check the knife edges have't moved, as they can be repositioned to the left or right when the trem is off.
Ant1981 is offline
post #7 of 7 (permalink) Old 12-27-2005, 12:21 PM
Re: LoPro Help!!
Check to see if any of the springs came off.
ryanb is offline
Closed Thread
ibanez jem
LoPro vs. Edge lcsdds Ibanez JEM, UV, JS & Other Signature Models 17 06-02-2008 04:12 PM
Feel of LoPro Edge 7 vs LoPro Edge 6 and other setup issues mdrobnak_rg7 Tech: Setup, Repairs and Mods 9 04-16-2003 02:56 PM
Which LoPro? Noodles Archived Topics and Common Questions 5 12-06-2002 05:29 PM
Gold LoPro 7? Platypus Gear, Equipment, Recording & Off Topic 8 07-28-2002 06:05 PM
OFR or lopro? - which rule? johan15 Tech: Setup, Repairs and Mods 26 07-06-2002 06:55 AM
