LoPro matching bridge radius to neck radius - Jemsite
post #1 of 11 (permalink) Old 05-01-2015, 03:10 PM Thread Starter
So still working on this old Jem BFP.
The G string is to high and pops out compared to the rest, you can clearly see it with the naked eye. the low E is too high as well. Below a pictured measured with a 17" radius gauche.
There are no shims installed atm. trem knives are currently perfectly level. I was under the impression that all lopro saddles were the same height since the base plate has the radius, or is that wrong? prefer to ask before removing them the check that.
Otherwise how would I fix this or what are the most common causes of such problems ? Seems odd that such an advanced trem would be delivered so off.
Rich, you mention the radius in your setup options when buying guitars. Do Ibanez's come with a wrong radius match out of the factory ? and how do you fix this ? thx!
Silverburst is offline
post #2 of 11 (permalink) Old 05-03-2015, 01:49 PM Thread Starter
Re: LoPro matching bridge radius to neck radius
Need input on this. Noone having this problem with Lo pro's ? thx
post #3 of 11 (permalink) Old 05-06-2015, 01:47 PM Thread Starter
aaaah cmooooooon, no one has this problem around here ? impossible! :P
post #4 of 11 (permalink) Old 05-06-2015, 03:45 PM
Sorry, post notifiers were down for a few days.
Does the radius gauge even match the frets?
I use the fret, wind the trem down so the string are laying on the frets. Make sure you've broken the strings off the saddle, the low E looks to be rising as it leaves.
Shims, copper shielding tape, I've even see scotch tape used.
Rich is offline
post #5 of 11 (permalink) Old 05-06-2015, 04:43 PM Thread Starter
thx for the input Rich
it's a 2 sided gauche, matches the fretboard perfectly. I'll double check with flattening the action.
thx
post #6 of 11 (permalink) Old 05-06-2015, 04:57 PM Thread Starter
hotd*mn... notching/breaking the low E when leaving the saddle as you suggested solved that problem! wasn't aware that this could make such a difference. Matches the radius gauche perfectly nowThis guitar is stringed with 46 which are a tad stiffer than the 42 I put on almost all my guitars. sharp eyeballing of you off of that picture.
The G is still too high, even after the breaking. So I'll take it of to see if I find any surprises underneath. I can feel the difference with my finger on the nosepart of the saddle compared to the D, which should be exactly level.
post #7 of 11 (permalink) Old 05-06-2015, 05:23 PM Thread Starter
ok, problem solved !
I removed the G string saddle, nothing below. I have 3 spare lo pro saddles around, compared with a calliper and this one was 0.007 (metric) lower on the nose compared to my 3 spares while it shows higher in the bridge. odd. But then I put the saddle back, felt no difference anymore... huh ? As I tightened the screw, near the final squeeze, I feel the saddle rising! probably because the saddle position is as such that it "almost" shows the furthest mounting hole 100% and using the screw in the first position pressed to hard on the tip of the nose. The tip of the nose is not 100% square edged resulting in a subtle convex shape at the tip, making the saddle's ass jump up a bit when using the front srcew hole! So I chose to push the saddle a bit further so the back mounting whole was in the clear and put the screw over there. Problem solved !
2 different problems made this a bit cloudy, but again, the simplest among explanations are often the right ones ! 2 lessons learned today
post #8 of 11 (permalink) Old 05-06-2015, 06:30 PM Thread Starter
The G is slightly flat at the 12th fret now though since the saddle is a tad too far.
post #9 of 11 (permalink) Old 05-06-2015, 08:07 PM
Exactly, it's no longer intonated. You have to shim all the other saddle to match the high one, if you don't have a lower saddle among the spares.
Rich is offline
post #10 of 11 (permalink) Old 05-06-2015, 08:17 PM
RGTFanatic's Avatar
I'm a little confused as to how you fixed the low-E string height. The G-string fix makes sense.
Another way to cure the G-string saddle problem and be able to intonate correctly would be to open the slot in the saddle the same amount you need to reach the rear bolt hole, plus a little more for good measure. The metal used in these saddles is pretty soft and easily workable. A .120 notching file would be PERFECT for this.
http://www.stewmac.com/Luthier_Tools...Nut_Files.html
On a related note- I have seen the washer that is supposed to be on top of the saddle (under the bolt head) underneath the saddle. Apparently someone let the washer slip down the bolt when installing the saddle. Obviously this wasn't your problem, but it may help someone else that comes across this thread looking for help.
RGTFanatic is offline
post #11 of 11 (permalink) Old 05-07-2015, 02:25 AM Thread Starter
Shimming all the rest to match up for one saddle that gets pushed up because the screw squeezes the the tip... Hmmm, no. I'll check if the problem occurs with me spares as well.
rgt, don't know if I have that much space left between the head of the screw and the back wall of the upper screw cavity, checking tonight. Thx
radius
My S570 Neck Vs. Bridge Radius Vs. Action Discovery fly_with_v All Other Guitars (including Prestige) 0 03-10-2011 06:11 PM
s7320 neck - bridge radius johnnyninja All Other Guitars (including Prestige) 3 07-14-2010 08:03 PM
Bridge radius vs fretboard radius F242 All Other Guitars (including Prestige) 4 11-21-2009 10:17 AM
Saddle Radius on Edge Not Matched to Fingerboard Radius? Zerimas Pickups & wiring 5 08-12-2007 05:03 PM
JEM7DBK nut/bridge radius differs from neck radius ?!?! jemoctave Ibanez JEM, UV, JS & Other Signature Models 5 01-30-2005 12:21 AM
