Loss of sustain at the 12th fret and above... - Jemsite
post #1 of 8 (permalink) Old 07-30-2011, 05:06 AM Thread Starter
I just noticed something peculiar today... My G string loses sustain at the 12th fret and above. The sustain is about half of the other strings when played at the same fret and it only affects this string. Anything below the 12th fret is OK though. The other strings are unaffected. Even my high E can sustain longer than the G which is odd as it has less mass and should vibrate lesser. Any ideas? It's an S470.
Lonerider is offline
post #2 of 8 (permalink) Old 07-30-2011, 10:38 AM
Reviews: 15
Re: Loss of sustain at the 12th fret and above...
Sounds like it's time for a fret leveling. It sounds like you either have a high spot, or the 12th has a low spot. If you want to avoid it, you can raise the bridge until it stops.
lespauled is offline
post #3 of 8 (permalink) Old 07-30-2011, 10:38 AM
Reviews: 15
Have you changed string gauges? How old are the strings? Try a new set. It might be a slight bend in that string.
post #4 of 8 (permalink) Old 07-30-2011, 12:46 PM
Reviews: 11
haha my s540 has this problem on the B string Im pretty sure a fret is peaking out just high enough to hit it but not cause buzzing.
linuxpenguin is offline
post #5 of 8 (permalink) Old 07-30-2011, 11:03 PM Thread Starter
I changed strings recently so I'm going to change that particular string and see if it works. How do I check if the frets are popping? will there be a gap between the wire and the fretboard?
post #6 of 8 (permalink) Old 07-30-2011, 11:06 PM
Reviews: 11
get a credit card and see if it rocks anywhere, that or get a REALLY high quality straight edge and check if you can see gaps anywhere.
post #7 of 8 (permalink) Old 08-01-2011, 07:51 PM Thread Starter
Tried a change of strings but the problem still persists. I'll try to check for high frets using a steel rule as suggested above.
post #8 of 8 (permalink) Old 08-02-2011, 09:58 AM
You may need a fret level. Sometimes the very end of the fretboard will curl up a bit over time. Also, if the frets are very tarnished, I've had this issue before. May also wish to check the neck angle.
Takin' a Ride is offline
s470 sustain
Teflon tape and loss of sustain/tone? kokyman Tech: Setup, Repairs and Mods 10 02-17-2011 11:59 AM
sustain loss on high frets Orochimaru Tech: Setup, Repairs and Mods 10 12-18-2008 10:59 PM
If I'm getting fret-rattle from the 12th to the 18th fret...? Superuser Tech: Setup, Repairs and Mods 0 02-03-2006 12:11 PM
Need Help! Loss of Sustain on Jem. clintalan Ibanez JEM, UV, JS & Other Signature Models 15 03-05-2004 07:05 PM
fret buzz - above 12th fret nat1201 Tech: Setup, Repairs and Mods 6 04-11-2002 12:29 AM
