LOUD noise after replacing 5 way switch - Jemsite
post #1 of 11 (permalink) Old 12-08-2015, 01:07 PM Thread Starter
Recently I had to replace my 5 way switch, as the one on my rg570 was shorting out (26 years old). I bought a new switch, and soldered everything on the way it was before, not touching anything other than the joints on the switch. So I plugged in the guitar, and the switch works properly (just a little touchy), but I have LOUD buzzing noise, especially on overdrive/distortion channels. I tried touching the ground wire and it didn't bring down the noise at all. Also, it's not the cord or the amp because it's only on that guitar. HELP PLEASE. I cri.
accidental is offline
post #2 of 11 (permalink) Old 12-08-2015, 07:17 PM
Re: LOUD noise after replacing 5 way switch
Sounds like it could be a bad/cold solder joint or a loose wire causing the problem. Double check all your joints. Loose wire(s) should be easy to spot but cold solders aren't always visually obvious. You may need to hit all your solders again with the iron to be on the safe side.
madasahatter is offline
post #3 of 11 (permalink) Old 12-08-2015, 11:56 PM
have a VOM? are you sure you dont get some coil split which of course would sound noisy under distortion?
Tap the pups poles (both coils in each humbucker) with some metal object (screwdriver) in each of the 5 settings and make sure you hear exactly what you were supposed to hear, as far as the 5-way function is concerned.
Also check that each of the component's ground is indeed connected to system's ground (ground tip + bridge).
This could help:
http://www.guitarnuts.com/technical/...uble/index.php
panix is offline
post #4 of 11 (permalink) Old 12-09-2015, 03:30 PM
RGTFanatic's Avatar
What switch did you use? I'm only guessing that one or more of the lugs in the switch were over heated. This can lead to all sorts of problems including the buzz your describing.
RGTFanatic is offline
post #5 of 11 (permalink) Old 12-10-2015, 01:28 PM Thread Starter
I used an OEM ibanez 5 way. It was strange because the tabs didn't have holes in them, so soldering was harder. I went over it again with the iron yesterday, still having problems. I noticed that there are some spots in the room where it doesn't buzz much, or at all. Maybe it's the switch itself?
post #6 of 11 (permalink) Old 12-10-2015, 07:11 PM
RGTFanatic's Avatar
does the room have a dimmer switch on the lights?
post #7 of 11 (permalink) Old 12-10-2015, 08:52 PM
Reviews: 15
did you check the schematics for the switch, or just match the existing soldering points?
The reason I asked was I swapped out all the stock wiring in my Epiphone Les Paul many years ago, and replaced them with Gibson parts. The gibson switch looked exactly like the epi, so I just matched the epi's wiring. I had a very similar result. After going online and getting the schematics for the Gibson switch, all was well in the guitar world.
lespauled is offline
post #8 of 11 (permalink) Old 12-10-2015, 11:00 PM Thread Starter
Nope. I don't think this would affect it considering my other guitars don't buzz.
Checked schematics, they're the same. I think I'll just buy a new switch from my lms tomorrow, put it in and see what happens.
post #9 of 11 (permalink) Old 12-10-2015, 11:32 PM
RGTFanatic's Avatar
Is your switch a YM-50 or a VLX-53?
can you show us the exact switch your buying?
post #10 of 11 (permalink) Old 12-11-2015, 09:16 AM Thread Starter
The new switch was a ym50, just like the original. My music store will probably sell me a crl fender style 5 way. I'm thinking it must be the switch, but I've replaced a fair number and never had this happen.
post #11 of 11 (permalink) Old 12-11-2015, 10:04 AM Thread Starter
Strange thing about the new switch though, is that the tabs to solder onto don't have holes in them like my other ym50s, they just have metal circles for tabs.
Loud noise when i plug on my MXR M-108 EQ micdreyer Gear, Equipment, Recording & Off Topic 0 03-20-2012 03:21 PM
Stock 5 Way Switch Popping Noise DogRox Pickups & wiring 14 12-22-2009 09:01 AM
Replacing the Switch Soulstryke31 Pickups & wiring 1 10-26-2008 09:26 PM
replacing stock switch kizo Pickups & wiring 3 10-04-2007 06:37 AM
Noise Volume Pot and 5way switch LennyNero Pickups & wiring 4 09-18-2002 11:08 AM
