Low B string too close to fretboard edge on my RG1027PBF? - Jemsite
post #1 of 5 (permalink) Old 01-03-2020, 01:45 AM Thread Starter
I just purchased my second Ibanez (my first premium) and I’ve noticed something while comparing it to my other 7 string, which is an iron label. It seems that the lowest string is really close to the fretboard edge. It seems the string is far enough from the edge as it gets closer to the body, but the first 5 frets or so it seems close to the edge. I’ve looked at multiple other people complaining about other guitars having this problem. Some say it’s a problem with the neck sitting a sideways in the pocket, others say it could be the nut etc. This is only my second Ibanez so it could just be how they’re made and it’s just different than my iron label. I would just like some opinions on the matter and to see if I’m overthinking something or if it’s something I can help by setting up the guitar correctly. If it comes to it I’ll use the warranty as I just bought it from guitar center and had it shipped to me, so that should be an option.
Pictures: https://www.flickr.com/photos/186298.../shares/c1iuM4
crownofnails96 is offline
post #2 of 5 (permalink) Old 01-03-2020, 03:21 AM
Re: Low B string too close to fretboard edge on my RG1027PBF?
In your case, nut seems to be problem. Neck to body angle looks correct. If guitar is keeper, ( good sound, good sustain, easy playing…) then change nut, or return it.
peromucho7 is offline
post #3 of 5 (permalink) Old 01-03-2020, 04:00 AM Thread Starter
As a small correction I just meant other random guitars from different brands people were complaining about on the internet. Not this model of guitar in particular.
post #4 of 5 (permalink) Old 01-03-2020, 01:13 PM
I agree with peramucho7. It does look as though the problem is your nut. The high E string tracks perfectly down the neck, so i can't see how it would be the neck not sitting correctly in the neck pocket.
JsXLine6 is offline
post #5 of 5 (permalink) Old 01-08-2020, 07:47 PM
webmaestro's Avatar
It's only a problem if you find yourself slipping off the fretboard during play. Is that what's happening?
If not, then it's cosmetic and I wouldn't worry about it too much.
If you ARE slipping off, then do what other's suggested: consider changing the nut (if the guitar is a keeper) or return it. I had a guitar once with this issue... where I would constantly slide off the edge of the fretboard even with normal fretting, and it was absolutely maddening.
webmaestro is offline
