Low E String detunes when using Tremolo Bar - Jemsite
post #1 of 5 (permalink) Old 02-01-2010, 10:50 AM Thread Starter
Unhappy Low E String detunes when using Tremolo Bar
Hi !
Last year I bought a Ibanez RG1570 with a Edge Pro Brigde . After changing strings ( I put a new set of strings, where the low E is thicker than the previous one , I think it is 0.46 but I am not sure about that ) , I had to setup the bridge accordingly, thigtening the springs in the back of the guitar, in the neck direction, to make the bridge paralell to body of the guitar. Everything is ok, but now i am having another problem. Since i have thigtened the springs, when I use the tremolo bar for big dive bombs for example, my low E string detunes half step down . Also I notice that my tuning is not very stable . Maybe it has something to do with not having setup the intonation yet
Any advice ?
Thanks,
Ivam
ifrias is offline
post #2 of 5 (permalink) Old 02-01-2010, 11:04 AM
Reviews: 23
Smile Re: Low E String detunes when using Tremolo Bar
Stretch your strings first.
theapprentice is offline
post #3 of 5 (permalink) Old 02-01-2010, 11:33 AM Thread Starter
The strings are not new. They have been stretched already
ifrias is offline
post #4 of 5 (permalink) Old 02-01-2010, 01:47 PM
If you didnt physically stretch the strings out it doesnt matter if you put them on for 6 months, they will still stretch a little. I suggest if your having tuning issues you start from scratch with a new set of strings and follow the tech setup guide at ibanezrules.com
sniperfrommars1 is offline
post #5 of 5 (permalink) Old 02-01-2010, 01:51 PM
Reviews: 12
that is the most likely the culprit... if all else seems to be in-tuned after doing dive-bombs, then only the low E saddle needs to be adjusted. Since you're already intonating the low E, doesn't hurt to check the rest of 'em just to be perfectly safe
Reg
reguv760 is offline
ibanez rg1570 , tremolo bar
FS: Lo-TRS 7 string Tremolo NickCormier Classified Ads: Guitars and Gear 1 08-30-2009 10:33 AM
WTB: 7 String Tremolo and Neck rgk7 Classified Ads: Guitars and Gear 0 04-12-2009 07:40 AM
doing tremolo dives detunes my guitar... help? MF_Kitten Tech: Setup, Repairs and Mods 21 07-12-2007 10:56 PM
weight of edge pro detunes? damo7v Tech: Setup, Repairs and Mods 26 03-12-2006 06:00 AM
