Low Pro --- Minor Problem - Jemsite
post #1 of 7 (permalink) Old 07-20-2004, 09:28 PM Thread Starter
When I'm playing the strings stay in tune but when I move the tremolo arm, even just a small dive bomb, the whole tremolo dives down with it and the angle of the tremolo changes to that direction until I pull it back up... Same thing goes with pulling up, it stays in that position. Eventually the strings go out of tune. How can I adjust the tremolo so that it goes back to being parallel with the guitar even after extreme dive bombs? Thanks and all help is appreciated.
excellentrocker is offline
post #2 of 7 (permalink) Old 07-20-2004, 11:57 PM
Sounds like it's touching the pickguard.
Rich is offline
post #3 of 7 (permalink) Old 07-21-2004, 01:23 AM Thread Starter
Nope, it's not THAT bad. I made a mistake on the post earlier, I'll edit that now.
Anyway what I meant to say was that pushing the trem down causes the angle to be changed into that direction, the whole tremolo doesn't stay in that exact same place. The same goes for pulling it up.
post #4 of 7 (permalink) Old 07-21-2004, 06:00 AM
Thats the first time I've ever heard of this kind of problem....wierd.....
Scott 74 is offline
post #5 of 7 (permalink) Old 07-21-2004, 11:31 AM Thread Starter
Do you think something is loose somewhere in the trem that messes up the angle?
Ahh, and one of the more annoying things about this problem is that when I have the pickup switch in the center the tremolo arm, after an even small dive bomb, is at a low enough angle to touch it (the switch). I've seen Steve Vai do huge dive bombs to the point where his strings are loose to the max and afterwards, still have the trem at the proper angle, not to mention still being in tune. Hopefully I'll get my trem working like that soon.
post #6 of 7 (permalink) Old 07-21-2004, 11:42 AM
Rich is offline
post #7 of 7 (permalink) Old 07-21-2004, 01:50 PM
If it's too low in the cavity the little saddle locking screws can bind agains the guitar's finish, or the wood itself if it's worn the finish away. Raising the action is not a fix for this, because now you have higher action. But it would tell you in a matter of seconds if that's the problem.
frankfalbo is offline
pickup switch , steve vai , tremolo arm
Minor scale vs. harmonic minor ironfistx Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 16 11-20-2012 07:13 PM
Having a minor problem Thendrall Tech: Setup, Repairs and Mods 16 02-10-2011 03:57 PM
Jam in E minor on My Jackson DK2 Rab Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 1 10-21-2010 07:53 AM
D minor......? Guitarist-Jonny Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 6 07-26-2008 07:13 AM
Minor Problem on New RG1570MRB guitarman13 Tech: Setup, Repairs and Mods 4 03-06-2007 11:25 AM
