Lowest E string slips...what's the problem? - Jemsite
post #1 of 3 (permalink) Old 01-31-2005, 02:19 PM Thread Starter
Hallo guys...i have a rg550ex, 2000. year of production...with lo pro edge...
I was trying to set the action as low as possible - i have set the trem angle as it is described on jemsite, tech page...but i am not sure about about bridge height...i had guitar with a floating trem before, and when i wanted to lower or raise the bridge height, i have used 2 screws on top of the trem...i would tighten them up clockwise to lower it and the oposite for raising( it was on a lo trs 2)...i am not sure is that proper way for lo pro?
Anyway, now, my first, the thinnest, E string slips down the fretboard when i try to vibrate it harder, and my action is even not extremely low (what worries me the the most is that i remember that my action was lower before, and i was not having this e string issue!)...
i can live with it, since i can vibrate it up, but it bothers me, since that is not the proper way, and i know that it was different before...
What should I re-adjust to fix this?
please help me- i am anxious to play my guit proparly since i have finally found that vai sound on my gear!
thanx...
pera_a777 is offline
post #2 of 3 (permalink) Old 01-31-2005, 03:24 PM
Re: Lowest E string slips...what's the problem?
It sounds like the Lo pro edge may have shifted to the side. Maybe it was a little off and it fell into place when you moved the screws. I would try loosening the 4 neck screws on the back, then pushing/pulling the neck so that it gives you a little more wood and the high e string isn't so close to the edge. There usually is a little bit of play in the neck pocket.
You can also try to adjust the lo pro by loosening the strings and pushing it over.
john1880 is offline
post #3 of 3 (permalink) Old 01-31-2005, 04:29 PM Thread Starter
It is hard to tell, but it seems to me that distance from the edge of the fretboard to the E string, either lower or higher, is the same....so that I don't understand why does the lowest, (i mean the thinnest string) slips off...i have tried to raise or lower the bridge again (by using 2 screws on the top of it) but string is slipping no matter at what height it is...?
And can some of you guys tell me what are your experiences with low E string (i must again to say THE THINNEST one, NOT THE TOP ONE) while playing at lowest possible, but playable action?thanx...
neck screws , pro edge
Which is the lowest tuning on guitar? ThePilgrim Tech: Setup, Repairs and Mods 11 04-30-2010 05:45 AM
lowest action without buzz extigy Tech: Setup, Repairs and Mods 26 09-06-2007 10:49 PM
getting the lowest possible action robbo12 Tech: Setup, Repairs and Mods 2 10-22-2006 11:05 PM
E string slips...what's the problem? pera_a777 Tech: Setup, Repairs and Mods 0 01-31-2005 02:18 PM
Trem height and action problem. - Lowest possible trem heigh Theater of Dreams Tech: Setup, Repairs and Mods 2 04-29-2002 03:45 AM
