Lubing Edge Zero Fine Tuners - Jemsite
 1Likes
  • 1 Post By sepulchrave
post #1 of 4 (permalink) Old 09-08-2018, 06:41 AM Thread Starter
These tuners are steel thumbscrews that screw into the alloy base-plate, operate under a fair amount of load, and get used quite a lot.
My concern is that the threads in the base-plate will wear; and this will be difficult/expensive to repair.
The obvious answer is to lubricate them.
Anyone do this ? How ? What do you use ?
scallybert is offline
post #2 of 4 (permalink) Old 09-08-2018, 07:59 AM
Re: Lubing Edge Zero Fine Tuners
You're overthinking this dramatically, I have fine tuning thumbscrews on Floyd Rose and Kahler trems from the mid-eighties which show absolutely no signs of wear despite no lubrication in nearly 35 years. Any lube you put on there will act like a magnet for fine dust and grit and the load is actually very small. I'm speaking as an engineer, not an artist.
Better coming to terms with your own mortality than worrying about that.
TJ777 likes this.
sepulchrave is offline
post #3 of 4 (permalink) Old 09-08-2018, 10:59 AM Thread Starter
You appear to know me worryingly well...
I do tune a lot, though...
post #4 of 4 (permalink) Old 09-09-2018, 05:52 AM Thread Starter
I use this on model helis, and it seems like a good match:
DryFluid Heli
edge zero , lubing
String Cleaning/Lubing Products scallybert Tech: Setup, Repairs and Mods 1 09-08-2018 10:19 AM
edge zero bolt and fine tuner SteveBye All Other Guitars (including Prestige) 0 09-10-2017 06:08 PM
Lubing knife edges MatiasTolkki Tech: Setup, Repairs and Mods 5 04-27-2015 01:48 PM
Edge zero vs Edge zero 2? e32lover Tech: Setup, Repairs and Mods 9 01-21-2015 11:49 AM
Lubing Knife edges on EZII MatiasTolkki Tech: Setup, Repairs and Mods 12 05-12-2014 02:59 AM
