Making a ZRII sustain block - Page 2 - Jemsite
post #16 of 26 (permalink) Old 10-16-2012, 06:05 PM
Re: Making a ZRII sustain block
Fair enough. Its still a significant upgrade. Although since in theory it'd be easier to just extend the block backwards wholesale, and that way it'd give you more mass, would there be an option, should you sell these, to do a version for people who don't use the ZPS? In theory its leaving a step of the process OUT, rather than adding one IN, so maybe?
Bear in mind I'm not a machinist, so I could be wrong :P
GuitarBizarre is offline
post #17 of 26 (permalink) Old 10-16-2012, 06:16 PM Thread Starter
Yep that would be the plan. The space would have to be machined out for the ZPS bar so that would be an extra step. It'd be easy to just leave that step out and give you a larger sustain block. But if it's tungsten, how much weight is too much? I don't think a lot of people want to add two pounds to an S, LOL. Once I have an approximate volume, I can figure out the weight. Tungsten is much more dense than brass and two pieces of the same dimensions will have different weights (tungsten weighing more). A brass one would need to be larger but that might be a viable and less expensive alternative to tungsten for those who don't plan on using the ZPS.
I'm going to make molds and hopefully have something "whittled" up by this weekend and then I'll see if I have a local shop who can do the machine work. If not, I'll have to find someone capable of working with tungsten. I found one shop already but if I can work with someone local, that's a bonus.
I'd invest in one of those rapid prototyping machines that print 3D plastic parts but that money is going towards guitars! Again, maybe someone in town has one. Decent ones can be had for well under $1,000 now.
MichelIV is offline
post #18 of 26 (permalink) Old 10-16-2012, 06:31 PM
Well, I'll certainly be keeping a close eye. My S2170 has been crying for more sustain since I bought her!
post #19 of 26 (permalink) Old 10-16-2012, 06:38 PM Thread Starter
I've got a S1520NT on the way and it has the Edge Lo-Pro. I've ordered a brass big block and brass claw for it as well so I'll have a pretty good reference to go by. I know the two will probably never be equal but it'd be nice to get close. Dunno what it is about the ZR trem that does this...
I also have a set of Dimarzio Gravity Storms with an HS-3 single going in to my S5470, not sure if it'll make any difference. I have one dead spot on my neck that's noticeable. An adjustment to the truss rod could probably change that, or move it up/down the scale. If I can just add enough material in the right place to at least even things out a bit, I'll be a happy camper.
MichelIV is offline
post #20 of 26 (permalink) Old 10-17-2012, 08:32 AM
Another guy has gone down this path,heres a link to the thread.
Scroll down for pics and design plans etc.
http://forum.ibanez.com/yaf_postst74...ue-solved.aspx
corey j grieve is offline
post #21 of 26 (permalink) Old 10-17-2012, 09:35 AM
Whoa! such weight should kill all the character of the instrument
mertay is offline
post #22 of 26 (permalink) Old 10-17-2012, 12:25 PM Thread Starter
Yep, I'm familiar with his endeavors and end result. I have his plans sitting on my computer's desktop. I tried to contact him but received no response. My goal was to create something which requires less work to install and doesn't change the basic functions of the stock ZR system and is not permanent. I'm going to try the tungsten sustain block first and go from there.
MichelIV is offline
post #23 of 26 (permalink) Old 10-18-2012, 01:58 PM Thread Starter
ZPS2 came in (Thanks Rich!) and worst fears were realized. The spring posts for the outer springs are either pressed or epoxied in (or combination of both). I was rather hoping for screwed in.
The entire assembly is featherweight. Really, really light.
Pics!
MichelIV is offline
post #24 of 26 (permalink) Old 10-18-2012, 04:15 PM
Reviews: 15
It might be possible to press the spring posts out and then have them threaded. Unless of course they're damaged while being pressed out.
silverctr is offline
post #25 of 26 (permalink) Old 10-18-2012, 05:59 PM Thread Starter
Maybe...they're pretty inexpensive but that's a lot of extra work and how many people would be really willing to do that? I may have a solution which won't require cutting or altering the stock setup and is reversible.
I'm picking my S5470 up after work today, new pickups installed. I told him about the sustain issue and he looked over everything for me and did a basic setup. The guitar tech had two other very good guitarists play it without telling them about the issue (post setup). Neither one noticed any sustain issues. I'll test when I get home. Will still proceed with the sustain block regardless but I wish he'd had them play it prior to the new pickups and setup. He did say the middle pickup is quite a bit quieter than the two hums. It's a noiseless HS-3 Dimarzio Single. Said it had good tone but was not nearly as loud as the two other pickups.
MichelIV is offline
post #26 of 26 (permalink) Old 10-20-2012, 10:25 AM Thread Starter
I put this link in another post. It's an interesting read and thought it was worth putting here too. Concerns dead spots on various guitars.
http://www.thegearpage.net/board/sho...dead+spot+neck
MichelIV is offline
block , s540 , sustain , tremolo , zr2
WTB Edge Pro 7 Trem Block (sustain block) magic_golem Classified Ads: Guitars and Gear 0 04-24-2011 03:49 PM
Floyd Sustain Block? RSVampire Tech: Setup, Repairs and Mods 13 07-04-2010 10:48 AM
Sustain Block Question Jason1635 Tech: Setup, Repairs and Mods 12 01-23-2010 06:41 PM
Sustain Block Reamemiya034 Ibanez JEM, UV, JS & Other Signature Models 11 04-18-2009 07:39 PM
Need a new sustain block for Edge Pro 7 sakeido All Other Guitars (including Prestige) 3 08-27-2008 12:00 AM
