maple top/laminate question? - Jemsite
post #1 of 24 (permalink) Old 01-19-2004, 05:26 PM Thread Starter
I have a frankgamble 400qm sig guitar with a quilt maple laminate. Is this a photocopy or actual quilt maple but very thin, other than the thickness you'd get on a les paul with a maple top?
big h is offline
post #2 of 24 (permalink) Old 01-19-2004, 05:33 PM
It is indeed maple, just a thin veneer. If it were a photo finish like the OLP guitars its appearance would not change under varying lights and angles.
frankfalbo is offline
post #3 of 24 (permalink) Old 01-20-2004, 09:44 AM Thread Starter
So is it used purely for a cosmetic effect rather than tone.
big h is offline
post #4 of 24 (permalink) Old 01-20-2004, 10:49 AM
For a better idea check the tutorials over at Project Guitar .com
syxxstring is offline
post #5 of 24 (permalink) Old 01-20-2004, 11:07 AM
Yes, a veneer is paper-thin and isn't going to have enough mass to affect the tone in any significant way. They're just for looks.
darren wilson is offline
post #6 of 24 (permalink) Old 01-20-2004, 11:51 AM
Some say the glue/veneer layer actually deadens tone. Personally, my 3 flamed sabre bodies were/are among the most resonant I've had; if this is DEADENED tone, they woulda been MONSTERS w/o the veneer...
Personally, I don't buy it; if done right I doubt it has much effect at all (but sure looks great!)
JESTER700 is offline
post #7 of 24 (permalink) Old 01-20-2004, 12:02 PM
Heh.
I could see glue/veneer maybe having some subtle effect on tone if the bodies were cut from the same log and were completely raw.
But once you've encapsulated the whole thing in a thick layer of polyurethane, i would imagine a thin layer of glue and a paper-thin veneer pretty much becomes a moot point.
post #8 of 24 (permalink) Old 01-20-2004, 01:18 PM
Originally Posted by darren wilson
...But once you've encapsulated the whole thing in a thick layer of polyurethane, i would imagine a thin layer of glue and a paper-thin veneer pretty much becomes a moot point.
Yes, amen. That's one thing I think makes my recently acquired RG6CST sounds so spunky...no grain filler and very thin finish.
A thin nitro finish might be cool on an Ibanez, eh?
Greg
gkelm is offline
post #9 of 24 (permalink) Old 01-20-2004, 03:49 PM Thread Starter
Okay I understand the veneer idea. But what about proper maple tops what do they do to the tone, and from a tone point of view does a flame/quiltmaple top have the same effect on sound as a plain maple top. And why are some tops described as aa, aaa, aaaaa I gather the one with more a's is better, but why? Who decides what is aa and aaaaa, what is the difference?
big h is offline
post #10 of 24 (permalink) Old 01-20-2004, 06:29 PM
Maple is heavy, dense, and bright. It will brighten a warm guitar (like say a mahogany Paul) if there's a good amount of it. Ugly maple will do this as well as a Ten Top flame or quilt jawdropper. The AAA thing is indeed a grade of the figuring and more As are better, but I dunno how they grade it. Plus, there are techniques to "bring out" the grain that's there, so that an AA top COULD look purtier than a AAAA.
post #11 of 24 (permalink) Old 01-20-2004, 08:20 PM Thread Starter
So as far as tone is concerned maple be it flame, quilt, bird's eye or plain is the same. I used to think that somehow flame/quilt maple was better than normal maple from a tone point of view because it's more expensive, but it's just the looks which makes it more sought after which I can understand. I imagine it must cost more than normal maple due to it being a more rare find. What do prs mean by a 10 top? Does that mean it is aaaaaaaaaa grade?
big h is offline
post #12 of 24 (permalink) Old 01-20-2004, 09:39 PM
Ten Top is PRS's name for "ultra purty", but I dunno how many "A"s that translates into.
post #13 of 24 (permalink) Old 01-21-2004, 09:03 PM Thread Starter
Thanks for replying. Keeping within a similiar subject of maple and its various guises. I read some specs on my fgm400qm sig guitar had a quatersawn maple neck, what does that mean?
big h is offline
post #14 of 24 (permalink) Old 01-21-2004, 09:28 PM
quartersawn refers to the angle to the grain of wood, thus the direction in which it is sawn..if that makes any sense. See
http://www.jemsite.com/axes/htm_features/necks.htm
Go to the middle, there's a thing called 'Neck dimensions', it also explains sawns.
Jeroenn is offline
post #15 of 24 (permalink) Old 01-21-2004, 09:28 PM
Quartersawn is when they cut the maple blank in such a way that the grains will run perpendicular to the strings. It's supposed to be stronger and more stable, as if the grains are like "I" beams and the wood will stand up to more pressure at that angle than if the grains run sideways. They say as the temperature changes, it shrinks and expands more uniformly, too. That being said, its still a numbers game. In a big factory where they don't have time to hand select blanks, there will always be some good and bad necks. Starting with quartersawn stock just improves the ratio. (and the tone in my opinion )That being said, the blank has to agree witht the fretboard too. If you have an uncontrollable ebony board it won't matter much what's under it, unless its something with graphite or steel rods inlayed like a carvin.
It's also a boast that doesn't always come true, but generally if a company is saying they use quarter sawn maple for the necks they aren't lying. But as you get to end pieces or out to the side the runout can minimize the quartersawn effect.
darren wilson , ebony board , eric johnson , ibanez rgt , les paul , maple neck , neck dimensions , neck thru , truss rod , truss rods
RG 550 Ltd maple question hozepipe All Other Guitars (including Prestige) 8 01-23-2010 10:47 AM
Question about maple necks GuitarEvan07 Tech: Setup, Repairs and Mods 2 05-08-2008 04:38 PM
FS: SCS Multi-Laminate JEM Body - Zebrawood & Purple Heart PatrickSimsCustomShopUSA Classified Ads: Ibanez JEM/UV Guitars 1 02-20-2008 02:46 PM
Question about maple veener. alex10 Tech: Setup, Repairs and Mods 2 08-16-2007 06:45 AM
3 or 5 pcs. Maple/Bubinga ??? Question GlamourZero Tech: Setup, Repairs and Mods 7 04-28-2006 07:41 AM
