Missing neck nut bolt - FGM - Jemsite
post #1 of 5 (permalink) Old 09-18-2016, 04:30 PM Thread Starter
Hi, picked up a guitar. A 1997 Ibanez FGM400. It's missing a bolt on the back of the neck where you lock in the nut. Does anyone know where I can find a replacement?
Ibanez site has this...
http://shop.ibanez.com/p/2ln1br43b-l...mm-black?pp=24
however, I just want the bolt that goes at the back. Also, not sure of the specifications and whether this modern part would work with a 97 FGM.
thanks,
K
kenmasters is offline
post #2 of 5 (permalink) Old 09-18-2016, 05:47 PM Thread Starter
Re: Missing neck nut bolt - FGM
Attached is a pic for reference.
[img]"http://www.jemsite.com/gallery/files/1/5/5/1/9/img_5848.jpg" alt="Fgm 400"[/img]
post #3 of 5 (permalink) Old 09-18-2016, 07:03 PM
Rich has them...
http://www.ibanezrules.com/parts.htm#Nut_Parts
I believe you want..
Mounting Screw Thru Mount 2TL23
Screw Flat Washer " 2TL24
Compression Washer " 2TL25
Double check with him to make sure these are the correct parts before ordering. Either way, he'll likely have what you need.
Congrats on the guitar. I love the FGM's
pwsusi is offline
post #4 of 5 (permalink) Old 09-18-2016, 07:07 PM
I'd pull the other and make sure you have the correct washers. That was a time when you never knew what they'd use.
Rich is online
post #5 of 5 (permalink) Old 09-18-2016, 09:43 PM Thread Starter
Thanks guys.. I'll take out the current one and snap a pic.
fgm
RG550 nut bolt cracks Sova Tech: Setup, Repairs and Mods 4 12-28-2015 10:26 AM
Ibanez bolt on basswood/bolt on mahogany/neck through KevinMarchesini All Other Guitars (including Prestige) 2 05-12-2012 08:19 PM
locking nut lock bolt loran333 Tech: Setup, Repairs and Mods 6 10-21-2009 11:47 PM
locking nut rear bolts missing? UK supplier? lemongrass Tech: Setup, Repairs and Mods 2 12-27-2008 02:11 PM
Locking nut attachment bolts missing guitarsalad14 Gear, Equipment, Recording & Off Topic 1 07-13-2007 11:27 PM
