Muted open string - Jemsite
post #1 of 7 (permalink) Old 03-19-2013, 02:40 PM Thread Starter
Muted open string
Just drop tuned to D standard. I am having two issues:
1. The G string, sounds a tad bit "muted" when played open
2. I'm getting a tiny bit of rattling on the C string, when played open.
I don't recall having these two issues when the guitar was in standard tune. And I don't hear anything when fretting the notes.
I have added a bit of relief to the neck, to no avail. I even raised the action, which did not help either.
It is only happening on those 2 strings. Guitar has a FR on it by the way, any ideas? Action is around 3.5mm measured on the 12th fret, low D.
Thanks
TheEYE is offline
post #2 of 7 (permalink) Old 03-19-2013, 04:31 PM
Reviews: 37
Re: Muted open string
your nut is too low and string are oscilating more downtuned.
im dealing with this right now in standard tuning on a hm strat with the wrong nut that is not radiused and it is muting the middle strings.
also that action is way high.
you should get 2 mm at 24 fret or 22 fret if a 22.
andrewsfury is offline
post #3 of 7 (permalink) Old 03-19-2013, 04:44 PM Thread Starter
Thanks. What can be done to fix this? I read that you have to use shims possibly?
It is the 5th and 4th string doing this by the way.
TheEYE is offline
post #4 of 7 (permalink) Old 03-19-2013, 05:03 PM
I'm having the same issue on my RG550. The high E sounds slightly muted when played open but sounds normal when fretted.
kfm946 is offline
post #5 of 7 (permalink) Old 03-19-2013, 05:09 PM Thread Starter
I'm pretty sure Andrew is right on, so I ordered the bronze shims from Stewart Mac 5min ago. I have tried trus rod adjustments and action, so I can't think of what else it could be.
TheEYE is offline
post #6 of 7 (permalink) Old 03-19-2013, 06:46 PM
Reviews: 37
Thats the ticket bro.
by the way i put a radiused ibanez nut on the hm strat and problem solved and plays like butter.
post #7 of 7 (permalink) Old 03-21-2013, 10:50 AM
You can also boost the gauge of your strings a bit to have a bit more string tension (hence less oscillation)
Arhythmic is offline
buzz , muted , rattling
Help please: Harmonic overtone on open G string. Blaklynx Tech: Setup, Repairs and Mods 8 08-13-2010 12:31 AM
Open string-buzz at high B & E Paw Tech: Setup, Repairs and Mods 7 04-23-2010 02:48 PM
Jem 77v open e string buzzing help Jesus jem Ibanez JEM, UV, JS & Other Signature Models 5 09-05-2009 03:01 PM
open string buzzing callen3615 Ibanez JEM, UV, JS & Other Signature Models 6 05-13-2008 12:09 PM
Open string buzzing eg Tech: Setup, Repairs and Mods 36 09-05-2002 02:44 AM
