Muting unplayed strings from ringing while using whammy? - Jemsite
post #1 of 13 (permalink) Old 02-16-2004, 11:51 PM Thread Starter
I've noticed that when I use the whammy bar, I get some unintentional ringing on unplayed strings. During normal playing, these strings are muted by my right hand, but when I lift that hand to use the whammy, they start to make noise. I usually try to mute them using any free left-hand fingers, but that's not always possible.
What do you guys do?
keithb is offline
post #2 of 13 (permalink) Old 02-17-2004, 02:44 AM
I usually roll my right hand off of the strings, that seems to keep them quieter than just lifting my hand straight off.
bachle7 is offline
post #3 of 13 (permalink) Old 02-17-2004, 02:45 AM
Fry
Try and be more finesse (don't know how to spell that.) You might be brushing the strings a little bit when you are lifting off your hand to use the trem, and then they really start to vibrate when you start using it. Try to lift your hand straight off.
Fry is offline
post #4 of 13 (permalink) Old 02-17-2004, 02:47 AM
Fry
lol, we posted at the same time, i didn't see yours until i viewed my own post. bachle7 is actually right, I meant to say roll your hand off, but I couldn't think of what to say.
Fry is offline
post #5 of 13 (permalink) Old 02-18-2004, 12:36 PM
or
Or you could buy that device they have for it that jennifer has pattened. My buddy has them on a few of his custom shops and uses them for 8 finger tapping and in the studio. It's mounted to your headstock and it's shaped like a T. there's a piece of foam at the end that touches right infront on the nut to mute out the open strings when you don't want them played. You can easily pull it down to touch the strings, or push it off and it goes back to where the headstock is out of the way... Or if you want to go ghetto style do what Reb did while recording with winger and tie a sock around the end of your neck... hahaha
BCShredder is offline
post #6 of 13 (permalink) Old 02-18-2004, 03:05 PM
bit too difficult to lift the muting thing up and then put it back down just to do one whammy bar dive or whatever. you'd have to flick the muting thing up with your left hand while you were using the trem then flick it back down and go back to playing, then do the same thing all over again. my advice is look at players who didnt have the kind of hardwear we have today, hendrix is considered the best guitarist ever, and he just wanked the trem off regardless of noise, make it part of your style
woodros is offline
post #7 of 13 (permalink) Old 02-18-2004, 05:14 PM
no
no you don't use it for the instance, you leave it down the entire time.
post #8 of 13 (permalink) Old 02-18-2004, 05:54 PM
yes i know, but not if you wanted to play open chords, from the sound of things this fella means while he's playing songs that require the odd whammy jobby, obviously if you were playing something that was all tapped it would be down all the time. i was just trying to be daft
get with the program y'all
woodros is offline
post #9 of 13 (permalink) Old 02-18-2004, 05:57 PM
Well, forget using that thing to do open string harmonic dives..
toshiro is offline
post #10 of 13 (permalink) Old 02-18-2004, 06:25 PM
he still could, it just doesn't let the open strings ring, that should be a problem as the only open you might do is an E and it would still give you a palm muted heavy sound you were going for in the 1st place.
post #11 of 13 (permalink) Old 02-18-2004, 06:33 PM
I use my left thumb and bring that around onto the lower strings to mute them, which leaves the other free fingers on my left hand to mute whatever else needs muting.
I have really long fingers though.
wil..
wilch is offline
post #12 of 13 (permalink) Old 02-18-2004, 07:41 PM
play it unplugged then the strings wont ring out as much, or at least you won't notice it. perfect.
woodros is offline
post #13 of 13 (permalink) Old 02-18-2004, 10:27 PM
Fry
Using the little sock trick around the neck, or some little device that is the same as the sock trick is weak. It is like riding a bike with training wheels. You gotta learn how to do it without extra help.
Fry is offline
custom shop , lower strings , palm mute
what's the longest your ears have been ringing? C.Thep Off-topic / Miscellaneous 43 07-18-2009 12:21 PM
Original Digitech Whammy, Warmoth 7 strings 4 sale! stretcher7 Classified Ads: Guitars and Gear 5 09-10-2007 06:01 PM
Ringing springs... Socialite Ibanez JEM, UV, JS & Other Signature Models 18 05-14-2003 01:55 AM
Jems ringing certain notes to feedback Vai the god of Sound Ibanez JEM, UV, JS & Other Signature Models 2 09-10-2002 10:22 AM
Unwanted ringing and string noises eg Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 3 09-10-2002 03:52 AM
