My FIRST Neck Build :D - Jemsite
post #1 of 204 (permalink) Old 06-16-2013, 07:38 PM Thread Starter
As the title says I'm working on my first neck from scratch, it going to be AANJ for an RG 470 body I'm going to do a fabric top on. Nothing spectacular as far as the wood goes since it's my first time I didn't want to ruin any expensive pieces.
It's five pieces, Maple in the middle, 2 small veneer strips of Walnut, and Red Oak for the outside pieces. Should look good if it all comes together, the oak has some nice grain to it. Since I've never even glued 2 pieces of wood together before, this should be fun...
Swirltop is offline
post #2 of 204 (permalink) Old 06-16-2013, 07:53 PM
Re: My FIRST Neck Build :D
Looking forward to the progress.good luck and may it turn out to your liking
Boombatty is offline
post #3 of 204 (permalink) Old 06-16-2013, 08:16 PM Thread Starter
Thanks Boombatty, I appreciate it buddy
Swirltop is offline
post #4 of 204 (permalink) Old 06-16-2013, 11:21 PM
Looking great!!!!!
GodzillaPopcicle is offline
post #5 of 204 (permalink) Old 06-16-2013, 11:33 PM
I'm in. I swear, everyone has those clamps!
GUITARMAGEDDON is offline
post #6 of 204 (permalink) Old 06-17-2013, 07:33 PM Thread Starter
Originally Posted by GUITARMAGEDDON View Post
I'm in I swear, everyone has those clamps!
HAHA!! I know right, they are cheap $15 for a 6 pack at Lowes
Not a whole lot more done, glued the rest of the headstock on and did some tracing. Think I'm going reverse headstock on this one thanks to GUITARMAGEDDON's project
Swirltop is offline
post #7 of 204 (permalink) Old 06-17-2013, 07:50 PM
May it go much better than my 1st swirl man! I'm looking fwd to seeing it come out!
ProgressiveHillbilly is offline
post #8 of 204 (permalink) Old 06-17-2013, 08:30 PM
glad I could help!, I will need to study this thread in the future b/c I'm sure one day I will have to at least try to build a neck..
post #9 of 204 (permalink) Old 06-17-2013, 10:22 PM Thread Starter
IDK if you'd want to study my build... You'd be better off going over to projectguitar.com and studying from the pros over there
Swirltop is offline
post #10 of 204 (permalink) Old 06-17-2013, 10:30 PM
I probably should have gone there anyway for my project
post #11 of 204 (permalink) Old 06-23-2013, 10:42 AM Thread Starter
So one neck project got side tracked by another neck project...
I am replacing the fret board on an old square heel RG550 neck. It will be going on my modified RG560 project.
Taking the board off was much easier than I thought it would be
Total time with the iron was about 30 mins
Close up..
Almost off...
OFF!!!
Swirltop is offline
post #12 of 204 (permalink) Old 06-23-2013, 10:50 AM Thread Starter
And here's the board that's going on it. From AI Guitars on the Evilbay. It did need quite a bit of work to get the inlays to actually fit in the routes as they were too rounded off in the corners. I used a utility knife with a new blade and sliced the corners sharp which magically made the inlays fit right... Go figure...
All glued in with epoxy:
Took them down with a file and then 220 grit sandpaper about as far as I care to go until I get up and go make a radius block to finish it off...
Swirltop is offline
post #13 of 204 (permalink) Old 06-23-2013, 01:57 PM Thread Starter
And sanded down and radiused...
There are a few rough spots and I need to fill in a couple places, but not too bad for my first time. It looks great until you look really really close up
Swirltop is offline
post #14 of 204 (permalink) Old 06-23-2013, 04:39 PM
wow man! looking good!!
post #15 of 204 (permalink) Old 06-23-2013, 05:00 PM Thread Starter
Thanks man!
Here she is after a ride on my new (to me) band saw... I just need to prep the old neck and glue it up at this point. Then it's on to my first full on fret job. I level and crown them all the time, but I haven't installed new ones yet
Swirltop is offline
Spalted Maple neck through js build :D linuxpenguin Ibanez JEM, UV, JS & Other Signature Models 47 08-28-2013 08:19 AM
My first neck build. wheeeeeeh!!!! andrewsfury Tech: Setup, Repairs and Mods 16 08-31-2012 06:13 PM
my pgm double neck build arispouncey All Other Guitars (including Prestige) 6 09-05-2011 05:32 PM
looking for a luthier to build a neck? 7 string neckthrough MorbidAngel All Other Guitars (including Prestige) 12 09-15-2003 08:39 AM
