nasty noise from prestige rg (that high fret warbling noise that you DONT want) - Jemsite
post #1 of 11 (permalink) Old 07-02-2008, 04:48 AM Thread Starter
hi
i have a friend's prestige 2550 (i think its a 2550, it has a pickguard and small dot inlays) at my house to set up for him and im having a strange problem.
you know that sound you get when the pickup/s are too close to the strings, it makes that warbling sound (wawawawawawa) particularly on higher frets on distortion on string G and B but also on others, it just seems to show more on these strings.
I tried lowering the pickups (to their minimum) and still it sounds as disgusting as ever!
The guitar is not perfectly intonated, could this have something to do with it?
im not sure what to do about, i think i can even hear it unamplified (am i going crazy?)
superhairycamel is offline
post #2 of 11 (permalink) Old 07-02-2008, 04:57 AM
Re: nasty noise from prestige rg (that high fret warbling noise that you DONT want)
If you've eliminated pickup height then check the intonation. You'd be surprised the difference it makes when a guitar is properly intonated. I suspect you have beats (http://en.wikipedia.org/wiki/Beat_(acoustics)) between the fretted note and one of the harmonics (possibly on an adjacent string).
Jim
Vim Fuego is offline
post #3 of 11 (permalink) Old 07-02-2008, 05:34 AM
I had this problem with my cheap Epiphone SG, intonating it didnt help.
I put new strings on it and re-intonated and the problem just went away.
scotte_za is offline
post #4 of 11 (permalink) Old 07-02-2008, 05:41 AM Thread Starter
i have to set it up anyway so ill change strings, intonate and see if theres still a problem PS its not BEATS because its only one string at a time.
thanks for you rquick responses!
post #5 of 11 (permalink) Old 07-02-2008, 06:48 AM
also reduce anything between guitar and amp. Remove all pedals etc. Happens on all the pickups?
Ibateur is offline
post #6 of 11 (permalink) Old 07-02-2008, 01:49 PM
GAZ
Sounds like very old,dirty and worn strings to me !!
GAZ is offline
post #7 of 11 (permalink) Old 07-02-2008, 02:26 PM
Same to me...
waylay00 is offline
post #8 of 11 (permalink) Old 07-02-2008, 10:49 PM
+1, I once set up a friend´s warlock which sounded just like you said in the last frets of the high strings, I just changed the strings and there was no more weird buzzing, I just intonated and that was it
rvai is offline
post #9 of 11 (permalink) Old 07-03-2008, 06:27 AM Thread Starter
gotta wait on the setup because i thought he said 9 - 46, but i put on a set of those suckers and whoaha the bridge went way up, so im trying to get onto him to ask if he want me to set up in 9 - 46 or maybe 9 - 42 like i guess he was using
post #10 of 11 (permalink) Old 07-03-2008, 11:57 PM
maybe you only have to stretch the strings so the bridge goes back to neutral? I´m almost shure that a setup with new strings will solve the problem
rvai is offline
post #11 of 11 (permalink) Old 07-04-2008, 08:00 AM Thread Starter
so is all set up, playing nice and intonated (took ages) and the problem of the noise has eased but is still not nice and def worse than my 570 which i have a tonezone in bridge...hhhhmnnnn.....
is it perhaps electronics?
pickups are still far from strings.
dot inlay , high strings , pickup height
Help, action high at 5th fret, low at 19th fret Rachmaninoff Tech: Setup, Repairs and Mods 3 06-06-2008 11:03 AM
JS 1200...warbling when pickign hard, trem noise etc... KissMyAxe Ibanez JEM, UV, JS & Other Signature Models 6 02-19-2006 08:45 PM
Noise gate for rack: need high quality, reasonable priced SilverSurfer2 Gear, Equipment, Recording & Off Topic 3 01-09-2004 02:28 PM
noise - ringing noise chip james Ibanez JEM, UV, JS & Other Signature Models 6 01-15-2001 07:08 PM
