Neck cleaning questions - Jemsite
post #1 of 15 (permalink) Old 02-10-2012, 05:36 PM Thread Starter
Developer
Hey everyone!
So I took apart my Ibanez Arc300DVS which has a mahogany body and neck. My fretboard seems dull and dirty right now. I was just wondering what I should use to clean it?
I have Pledge (I've heard it's alright if used in small quantities, and I also have mink oil (It's the only oil I have right now, and i doubt it's meant for any type of wood, it looks like it's used for leather... but hey.... who knows...)
I really don't want to go out and buy lemon oil or whatever else, so I was wondering what you guys do!
Thanks,
Brett
Verus is offline
post #2 of 15 (permalink) Old 02-10-2012, 06:52 PM
Re: Neck cleaning questions
Lemon Oil. Just go out and buy lemon oil.
BlanK is offline
post #3 of 15 (permalink) Old 02-10-2012, 07:03 PM
Lemon oil. Just go out and buy lemon oil. PLEASE
TMatt142 is offline
post #4 of 15 (permalink) Old 02-11-2012, 02:14 AM
Reviews: 10
Some guys swear by lemon oil. But I'm not a fan of anything with a citric acid being used on my guitars bare woods. Regardless of post treatment.
I simply use murphy's oil soap and water solution. After things are clean some sort of conditioner if your fretboard still carries a dull appearance. Multiple applications depending on the neglect might be necessary.
bhuard75 is offline
post #5 of 15 (permalink) Old 02-11-2012, 03:31 AM
Use what is designed to clean unfinished wood. I don't know how Murphy's Oil Soap would react to the glues for inlays. Just don't use Pledge.
BlanK is offline
post #6 of 15 (permalink) Old 02-11-2012, 11:13 AM
RGTFanatic's Avatar
This is just plain bad advice
Do NOT use Murphy's mixed with water on your fretboard...EVER!!!
Direct from Murphy's FAQ: ( http://www.colgate.com/MurphyOilSoap/faqs )
"Q: How can a water-based cleaner be safe for wood floors, furniture, and other wood surfaces?"
"Answer: Murphy® Oil Soap is recommended for cleaning finished wood. It is not recommended for cleaning unfinished or waxed wood because the wood may be water-sensitive. Most wood flooring and furniture items have water-resistant finishes, and Murphy® Oil Soap is perfectly safe for use on these types of surfaces. If you're cleaning antique wood furniture, be sure to use caution since the finish may be worn. Always test first with plain water in an inconspicuous place. Murphy® Oil Soap should not be used on unfinished wood or on wood that needs refinishing."
Verus, do yourself the HUGE favor of buying a bottle of Weimann's 100% natural lemon oil......it's silicate free.
Ryc
RGTFanatic is offline
post #7 of 15 (permalink) Old 02-11-2012, 12:10 PM
mink oil ?
sounds like you are supposed to rub it in your hair to attract females.
LostInRockFormations is offline
post #8 of 15 (permalink) Old 02-11-2012, 12:14 PM
big thread about it here,
http://www.jemsite.com/forums/f11/lemon-oil-3257.html
post #9 of 15 (permalink) Old 02-11-2012, 01:37 PM
MInk oil bad, Murpheys bad, pledge bad,
lemon or lindseed oil, GOOD.
musikron is offline
post #10 of 15 (permalink) Old 02-12-2012, 05:34 AM
Reviews: 10
Ryc
Bad advice based on what? A general disclaimer from a manufacture's website thats clearly their to cover their @$$. Roofing hammers come with disclaimers also, carpenters still use them though.
Cleaning a fretboard with Murphys oil soap with some warm water on a damp rag and wiping it down is bad advise? I didnt recommend soaking the neck in a bucket of water. I didnt recommend to the OP using Murphy's Oil Soap on their guitar period. I stated it was what I used.
Straight from the Ernie Ball website. A demonstration video clearly using Murphy's Oil Soap. Its even used on a signature model that has a wax finish on the neck.
http://www.ernieball.com/eb-tv/produ...r-drew-montell
bhuard75 is offline
post #11 of 15 (permalink) Old 02-12-2012, 10:39 AM
Ive never tried lemon oil. I use bore oil, based on advice from rich. I find it works well for me.
http://www.beafifer.com/
I also followed rich's advice and use saliva to clean my guitars. Although that could be out of laziness...
hangingmonkey is offline
post #12 of 15 (permalink) Old 02-12-2012, 03:25 PM
RGTFanatic's Avatar
Seriously??
water in wood swells the wood.....on a fretboard, that is BAD for a plethora of reasons.
Based on the manufactures instruction (not a disclaimer).If a manufacturer says "Don't use this product on unfinished or waxed wood" who's advice do you take? The manufacturer that knows the product inside-out, or an EB tech that (possibly) has no idea how it's made or why not to use it. For me, that's an easy decision.
If this method is your favorite Go for it!! I truly have no issue with you doing what you like......it's your guitar!! I do worry when you put out that this is an acceptable method to other players. IT IS NOT ACCEPTABLE. When giving advice to less experienced people, even in the guise of "this is what I do", it's always prudent to err on the side of caution and if your not 100% positive that your method cannot hurt another persons gear, it's best to say nothing.
Not that it makes a difference, but the spray cleaner used in the EB vid is cut with lemon oil........they've recently switched to orange oil for the same product. Either way...neither is cut with water. FWIW....warm water is even worse....it sinks into your fretboard even faster and deeper.....it would need AT LEAST a solid 24 hours to dry. Conditioning before that will likely seal in that water. If you don't like citrus based cleaners, thats understandable. Citrus oils can break down lacquer finished if not thoroughly cleaned....something I failed to mention in my own post. There are PLENTY of products available that contain no water or citrus. Maybe you'll want to look into them for your own benefit.
BTW....I've been a carpenter for 31 yrs. We don't use roofing hammers....roofers do.
Ryc
typical roofing hammer:
typical carpenters (framing) hammer:
post #13 of 15 (permalink) Old 02-14-2012, 12:39 PM
Is murphys oilsoap safe to use? Or can I just use fast fret alone or is it ook to use it and oil soap (of course not al the same time lol)
iloveibanezguitars is offline
post #14 of 15 (permalink) Old 02-14-2012, 12:54 PM
Dude, read the thread, it plain as day.
musikron is offline
post #15 of 15 (permalink) Old 02-14-2012, 06:32 PM
How do these threads continue on the way they do???
I'll never get it......... HAHAHA
There is some debate about the acidity in lemon oil and fret corrosion. I have never seen it, possibly because i never keep my guitars long enough
I also think a damp towel (NOT wet) probably does no harm , i would rather not use it though
Personally i use the Gerlitz line of products and am very happy with it.
Fast fret is a string not fret board cleaner
dragsternj is offline
Cleaning Satin neck? fwd0120 Tech: Setup, Repairs and Mods 14 06-21-2011 06:55 PM
Nooby Question: Cleaning the neck (not fretboard, neck!) mango_icecream Tech: Setup, Repairs and Mods 8 05-12-2008 09:03 PM
550 Neck cleaning??? poiter All Other Guitars (including Prestige) 3 02-15-2007 05:47 AM
Just a few questions about fretboard cleaning Dr Mindcrime Tech: Setup, Repairs and Mods 6 10-26-2004 11:53 PM
Cleaning Neck with strings on? ner0z Tech: Setup, Repairs and Mods 7 06-14-2004 06:20 PM
