Neck Frenzy - Jemsite
post #1 of 30 (permalink) Old 08-09-2011, 01:07 PM Thread Starter
Neck Frenzy
Got some swirled bodies in the Jem & Uni forum, so figured I needed to make some necks for them.
Glued up some maple and wenge over the weekend
Managed to bandsaw out to get 3 necks without scarfs & a couple with
Drilled tuner holes while the headstocks were over thickness so you don't have to worry about tear out on the back and while the side of the neck were square did the truss rod channel
Band saw out the headstock shape so the router doesn't have to remove too much material
headstock template routed to shape
more in a bit.
andyt is offline
post #2 of 30 (permalink) Old 08-09-2011, 01:25 PM Thread Starter
Re: Neck Frenzy
and the others
then same process for the neck shape, bandsaw away as much as possible, then using another template stuck to the neck blanks with double sided tape finish off on the router
and a quick neck fit test
andyt is offline
post #3 of 30 (permalink) Old 08-09-2011, 01:48 PM
Re: Neck Frenzy
So are scarf-free necks preferred? I would think so. That is some nice work. I love the flamed maple!
andrewgosline is offline
post #4 of 30 (permalink) Old 08-09-2011, 03:20 PM Thread Starter
Re: Neck Frenzy
Not really, its all swings, roundabouts, COST SAVING and personal preference
Fender straight neck made out of a 1" thick piece of wood
Gibson angled quartersawn, think you need a block about 3"
Scarfed seems stronger than gibson style as the grain of the wood is straight across the bit that always snaps + wastes less wood.
Laminated necks mostly more stable for twisting & warping
etc
andyt is offline
post #5 of 30 (permalink) Old 08-09-2011, 04:09 PM
Super Moderator
Re: Neck Frenzy
It looks like you've got a little factory running in there amigo!!! Either that or the UK's biggest garage?!?!
jono is offline
post #6 of 30 (permalink) Old 08-10-2011, 06:30 AM
Reviews: 17
Re: Neck Frenzy
Amazing stuff, Can I come down and learn from you? :P haha
Speedabob is offline
post #7 of 30 (permalink) Old 08-14-2011, 02:29 PM Thread Starter
Re: Neck Frenzy
Jono, I wish, when I built the shed thought it was about right, now especially since I moved in the hot tub (aka the new swirl tank) theres not enough room to swing a cat, let alone a guitar - yngwie stylee. The spray setup is in another shed, wish I'd built one twice the size.
Speedabob, just start reading Projectguitar.com - thats all I've done in the last couple of years, all you need to know is on there.
Had a couple of boards waiting ready to glue on - ebony & made a paduk stem, waiting for some fluro green leaves & maple with usual neon pyramids.
Got to do something with this V, not sure what yet.
andyt is offline
post #8 of 30 (permalink) Old 08-14-2011, 03:13 PM
Reviews: 17
Re: Neck Frenzy
Arch top that V, 2 humbuckers, 1 volume, 3 way pickup selector, ebony board, keep that colour
post #9 of 30 (permalink) Old 08-14-2011, 04:01 PM
Super Moderator
Re: Neck Frenzy
Well... you can always finish building it and send it my way
jono is offline
post #10 of 30 (permalink) Old 08-16-2011, 04:30 AM
Reviews: 34
Re: Neck Frenzy
Exactly what I was thinking!
nickcoumbe is offline
post #11 of 30 (permalink) Old 08-16-2011, 11:30 AM Thread Starter
Re: Neck Frenzy
Is it wrong to get excited about little bits of coloured plastic?
andyt is offline
post #12 of 30 (permalink) Old 08-17-2011, 11:20 PM
Re: Neck Frenzy
awesomeness
WillTubarao is offline
post #13 of 30 (permalink) Old 08-18-2011, 07:59 AM
Re: Neck Frenzy
Great wood working skills.
philster_d is offline
post #14 of 30 (permalink) Old 08-18-2011, 08:46 AM
Re: Neck Frenzy
I'm guessing your going to keep a few and sell the rest???
sebastian is offline
post #15 of 30 (permalink) Old 08-18-2011, 04:01 PM Thread Starter
Re: Neck Frenzy
Boards glued on, inlays in and filled, rough sanded
andyt is offline
neck building
FS: RG550 Maple neck/Edge Trem, Jackson neck, Dimarzio pups NickCormier Classified Ads: Guitars and Gear 10 01-08-2010 12:46 PM
Flamed jackson neck, birdseye musikraft neck, loaded strat body shesky Classified Ads: Guitars and Gear 2 04-30-2009 06:02 PM
Nine Year Old Plays "Frenzy" by Racer X redaxe Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 17 12-09-2008 10:36 PM
bidding frenzy on RG770 martysea Vendors, Auction & Reseller Talk 12 06-30-2008 09:26 PM
ok, ibanez switch H-H, pos1 = neck(hum mode) pos2 =neck(Inner Coil only) 7-request Pickups & wiring 2 07-05-2005 11:18 AM
