Neck question? - Jemsite
post #1 of 8 (permalink) Old 10-09-2019, 07:48 PM Thread Starter
Neck question?
I have a 1986 Ibanez RG410 Roadstar ll with the single slant humbucker and original edge trem and 22 fret neck. The fretboard on the neck has been damaged. My question is, will a neck off a 1987-89 neck from a Ibanez 540R or 540S fit without having to make any changes? Is the neck pocket depth, width, and neck specs the same? Thx
Woogie is offline
post #2 of 8 (permalink) Old 10-10-2019, 06:15 PM Thread Starter
Anyone?
Woogie is offline
post #3 of 8 (permalink) Old 10-10-2019, 08:36 PM
Quick answer is probably not. Do some research for the specs on those, but after 86 bodies & necks changed dramatically for the IBANEZ lineup. Check about for used Roadstar 2s I picked up an 85 for cheap as a project guitar. Probably 84-86 necks will be a better fit, although some shimming or sanding may be required for a proper fit.
snaggleyoda is offline
post #4 of 8 (permalink) Old 11-02-2019, 07:57 AM
Re: Neck question?
It has the fender style neck pocket, so yes it should fit with no issue. Even a JS 22 fret neck would fit perfectly. I just put a 540S neck in a 540R. Plus has a warmoth neck in one too. The pocket is the same. Hell my Kramer Baretta Neck fits in the 540 R as well.
JsXLine6 is offline
post #5 of 8 (permalink) Old 11-14-2019, 11:57 PM
Re: Neck question?
I think it will fit without major mods. Check the pocket with some calipers and then just have the person you are buying the neck from do the same. Then you don't have to worry about.
metaljake is offline
post #6 of 8 (permalink) Old 11-16-2019, 03:14 PM
Re: Neck question?
Which begs the question, how can a classic rosewood/maple/ebony fretboard get damaged?
xinap is offline
post #7 of 8 (permalink) Old 12-12-2019, 01:17 PM
Btw i have a 1987 540s neck with prestine frets if you are still interested in one. Frets have 95+% life.
JsXLine6 is offline
post #8 of 8 (permalink) Old 02-25-2020, 04:30 AM
Re: Neck question?
govindkori is offline
