Neck shim on Jem777 30th? - Jemsite
post #1 of 8 (permalink) Old 04-10-2018, 02:37 PM Thread Starter
Question Neck shim on Jem777 30th?
Hello, all. The action is roughly 1mm higher at the 21st fret across all 6 strings than it is at the 11th fret on my Jem777 30th Anni. When I played my friend's 30th Anni. I could feel and later measured that the action at the 21st fret was EXACTLY THE SAME as the 11th fret...as is the case on all my other high-end guitars. I believe this is how it should be and want that same consistency on my recently purchased $3500 guitar. Would shimming solve this?
I happen to have a Stew-Mac 0.25 degree neck shim on hand that I purchased but never used. Would this be appropriate to solve this issue? Any other suggestions?
Thank you!
P.S. Besides this issue I am completely in love with this guitar. I often find myself staring at it across the room in a dream-like gaze as if it were a beautiful woman...
JerkChicken is offline
post #2 of 8 (permalink) Old 04-10-2018, 03:26 PM
Re: Neck shim on Jem777 30th?
30th's do not need a neck shim.
Rich is offline
post #3 of 8 (permalink) Old 04-10-2018, 03:34 PM Thread Starter
Is there any reason then for the difference in string height at aforementioned frets? Why does one 30th have the issue and the other doesn't? Would not a slight shim solve this issue?
post #4 of 8 (permalink) Old 04-10-2018, 03:39 PM
Lowering the action solves it, there is no "issue" but a lack of knowledge.
Rich is offline
post #5 of 8 (permalink) Old 04-10-2018, 03:56 PM Thread Starter
Oh ok. Thank you. I was under the (incorrect) assumption lowering the action would simply drop the string height across the board, retaining the discrepancy from the 11th to the 21st fret. I'll adjust it tonight. Thx.
post #6 of 8 (permalink) Old 04-10-2018, 04:04 PM
If it's too close at 11 you add more neck relief.
Sit down with your friend and have him demonstrate how to set it up.
Rich is offline
post #7 of 8 (permalink) Old 04-10-2018, 04:12 PM Thread Starter
Great. Thanks! Will do.
post #8 of 8 (permalink) Old 04-11-2018, 08:57 AM Thread Starter
You were absolutely right, Rich (not surprisingly). Thank you for your help.
jem777 30th
FS: Jem777 30th Lochness Green (EU) El Nowy Classified Ads: Ibanez JEM/UV Guitars 4 08-16-2018 07:00 AM
JEM777 30th Anniversary Pre-Order registry (UK only) superclarkey Ibanez JEM, UV, JS & Other Signature Models 173 09-14-2017 06:14 AM
JEM777 Reissue 30th Anniversary in Canada tml069 Ibanez JEM, UV, JS & Other Signature Models 27 05-21-2017 02:38 AM
Jem7V WH vs Jem777 30th Anniversary Reissue maxpower2112 Ibanez JEM, UV, JS & Other Signature Models 15 02-18-2017 12:26 AM
JEM777 Reissue 30th Anniversary superclarkey Ibanez JEM, UV, JS & Other Signature Models 9 02-02-2017 02:31 PM
