need advice on lo-trs 1 stud repair - Jemsite
post #1 of 6 (permalink) Old 04-11-2013, 02:30 AM Thread Starter
I have an old '92 EX-350 w/ the lo-trs1 and the crappy laminate 'particle board' basswood body. I recently tried to swap out the lo-trs1 with a floyd rose special since the lo-trs1 was damaged. Upon trying to install the floyd, i found out that one of the tremolo stud holes was damaged. The stud was leaning forward and the wood on the underside (in the trem cavity) was starting to crack in the same spot as where the stud hole was located.
I took everything apart, and when I did, the 'bad' trem stud fell right out, and the cracked section of wood on the underside basically broke off as well. so now there's a tunnel from the trem cavity through to the damaged stud hole.
pics of the damage can be seen here:
h t t p : / / s1273.photobucket.com/user/Chango_Surf/media/20130408_223608_zps68f5883f.jpg.html
[i tried to post a link to the image but the forum didnt let me]
I read elsewhere on the forum that normally you'd just drill out the hole, install a piece of 'hardwood dowel', and re-drill the stud holes. However, in this case, Im not sure what to do, since Im worried that the thin section of wood between the trem cavity and where the dowel will go is going to be too weak to hold the dowel in place (i.e., the forward-pull on the dowel from the string tension & trem dives might also cause it to 'break through' the backside into the trem cavity, since the section of wood that should hold it back is weak,thin, & crappy).
So, basically, my question is: what would be the best way to go about trying to repair that stud hole? use the dowel method, or try something else? any advice would be appreciated...also, please keep in mind that im a 'noob' at this type of 'woodworking' guitar repairs, so please keep it simple & easy to follow.
csurf is offline
post #2 of 6 (permalink) Old 05-03-2013, 09:25 PM Thread Starter
Re: need advice on lo-trs 1 stud repair
bump, never got any kind of response.
can someone please help me out?
csurf is offline
post #3 of 6 (permalink) Old 05-04-2013, 01:36 AM
Your link doesn't work . You need to higher your post count before you can post pics .
Zoot is offline
post #4 of 6 (permalink) Old 05-04-2013, 02:31 AM Thread Starter
the link will work if u copy & paste it into the address bar and then remove the spaces toward the beginning of the url.
i understand about the post count issue, but i basically found&joined this forum only because I was looking for info on this specific electric guitar model, and I need the help&info now, so I cant really wait around trying to build cred on the forum simply to get some help. hope this makes sense.
please help, thanx
csurf is offline
post #5 of 6 (permalink) Old 05-04-2013, 03:09 AM
Reviews: 11
Relax. Wood glued together is stronger then the original wood. Dowel away my friend.
linuxpenguin is offline
post #6 of 6 (permalink) Old 05-04-2013, 10:16 AM
RGTFanatic's Avatar
how much experience do you have with woodworking tools?
The reason I ask is that there are two approaches to fixing this. The first is to route the entire area out and replace with a new basswood block, then drill a new bore for the stud anchor.
The second method is easier, but will be more prone to breaking again. Drill the anchor bore wider and fill with a dowel, then re-drill the dowel for the anchor, afterward you can fill the "tunnel" with wood filler. The filler will add NO structural integrity. This is why the whole section could break out again.
RGTFanatic is offline
tremolo anchor repair
JEM with Cracks in body on stud holes - repair? Claudio Passamani Ibanez JEM, UV, JS & Other Signature Models 1 02-02-2012 01:15 PM
JS100 tremolo Stud repair and paint stripping gtorob Tech: Setup, Repairs and Mods 6 02-05-2010 04:28 PM
Strap lock questions+repair advice kotornut Tech: Setup, Repairs and Mods 26 03-24-2008 06:52 PM
Stud mod Hosehead Tech: Setup, Repairs and Mods 2 09-05-2006 03:22 PM
1527 Locking Stud / Locking Stud Mod Societysucks All Other Guitars (including Prestige) 1 07-05-2004 09:26 PM
