need EDGE PRO specs - Jemsite
post #1 of 8 (permalink) Old 01-18-2010, 10:26 AM Thread Starter
need EDGE PRO specs
Can any one tell me if there are different EDGE PRO TREMS. I know there
are some for 6 and 7 strings, but wondering about stud spacing and if there are different specs for differnt guitars. Or is there just one model? I guess what I am trying to say is, if I buy a EDGE PRO
will it fit on a guitar set up for an edge pro, or is there a RG model, and a prestige model etc.
CHUCK STUTZ is offline
post #2 of 8 (permalink) Old 01-18-2010, 01:29 PM
Reviews: 37
Re: need EDGE PRO specs
Yes they are the same , edge pro is edge pro and edge lopro is edge lopro , and edge is edge no differences other than colors and string amounts.
andrewsfury is offline
post #3 of 8 (permalink) Old 01-18-2010, 02:16 PM
Well, technically there was an Edge Pro II briefly, but even that was really a separate model. If what you have is an actual Edge Pro, it should have the same specs as all other Edge Pros out there.
djohns74 is offline
post #4 of 8 (permalink) Old 01-18-2010, 07:58 PM
Yeah, but the EPII was exactly the same dimensions as an EP, but didnt have the metal chip things where the string touched the saddle. Other than that (and maybe different metals used to make it) they were the same. The EPII was a lower end trem, and was replaced by the Edge 3.
littlephil is offline
post #5 of 8 (permalink) Old 01-18-2010, 08:01 PM
The EP2 was vastly different that the EP. They may have looked similar on the top, but look at the bottom.
Rich is online
post #6 of 8 (permalink) Old 01-20-2010, 01:32 AM
Well, yeah the block is different because of the arm holder, but they are still pretty much the same dimensions. The EP is a drop in replacement for the EP2, isnt it?
post #7 of 8 (permalink) Old 01-20-2010, 09:26 AM
Dimensions has nothing to do with it. They are completely different. The EP2 has a screw on knife edge plate, and integrated arm holder/block you have to pull the whole bridge apart to replace the bushing. Different fine tuners, different studs, the biggest question is what is even remotely similar about the two? Besides the dimension.
Rich is online
post #8 of 8 (permalink) Old 02-23-2010, 02:18 PM
its not, coz if you try to put it in you have to carved some space so the edge pro 2 can fit it in because of the block or else you cant pull up the trem and i tried it..
IBANEZRG320DXFMTG is offline
edge pro
Screw specs on Edge/ZR trems iBZnOrange Tech: Setup, Repairs and Mods 0 05-02-2008 03:21 PM
I need specs on an amp fluxcapacitor Tech: Setup, Repairs and Mods 0 12-29-2006 01:53 AM
Need help with specs ihateemokids666 All Other Guitars (including Prestige) 15 05-16-2006 07:53 PM
Need help with RG7 specs! kevin7 All Other Guitars (including Prestige) 0 09-22-2005 10:19 PM
RG 2027x: What are the specs? - What are the specs of the RG Vai RuIes Ibanez JEM, UV, JS & Other Signature Models 3 09-07-2001 12:09 AM
