Need help with JPM project - Jemsite
post #1 of 6 (permalink) Old 05-11-2015, 10:48 PM Thread Starter
I just bought this from Perle:
Attachment 4698
It's made of basswood.
To be honest, I have no idea how to finish it. I would like to do the multi-color scheme of the original JPM model, but I don't know how to go about painting it. I was also thinking about staining the wood different colors, but again, I don't know if it would work. I really don't want to screw it up. The other issue is that I live in an apartment in the city, so spray painting or using toxic substances is probably out of the question.
Does anyone have any suggestions?
Thanks.
morchiant is offline
post #2 of 6 (permalink) Old 05-19-2015, 09:29 AM
Re: Need help with JPM project
I've given this some thought over the last few days on the best way to tackle this project given your situation. Ultimately for a multi-colored pattern like this painting would be best but if you can't spray paint you may be able to pull it off with stains.
If you can get access to an area where you can spray, spay paint (you can use rattle cans just don't use krylon) and spraymax 2k for the clear. The basic process for painting is:
1. Apply sanding sealer and then lightly sand it level.
2. Spray a couple of light coats of primer then lightly block sand it level.
3. Do your masking and spraying of colors.
4. Spray your clear coat.
5. Wet sand going through the grits of sandpaper then polish.
* On your paticular guitar I would paint the grooves that make the design using a steady hand with a fine tip brush & black paint before spraying the clear coat.
There's a bunch of sources on the web for more detailed instructions on how to spray paint a guitar.
If you just can't get access to an area where you can spray then staining the different colors then applying a wipe on oil finish like tru-oil would probably work best. The main concern with this would be colors blending together where they meet. You do have the grooves in the design that will help keep the colors seperated. Basically you apply your color stains, just be really careful around the edges of the pattern where colors will meet. I'd probably do a black stain in the grooves using a fine tip brush to apply it. Then wipe on the oil finish. I've used tru-oil as pore filler and top coat with nice results. Then lightly level sand and polish it up. The oil finish won't have a full on mirror finish like you can get with a splay clear coat but will still polish up nicely.
I would start with trying the staining process first and if it doesn't come out good you can always paint over it.
The last option would be to pay someone to do it professionally for you.
madasahatter is offline
post #3 of 6 (permalink) Old 05-19-2015, 08:29 PM
RGTFanatic's Avatar
I'm with Mad here, I think staining/dying is your best option BUT you need to know that Basswood is very bad at taking stain evenly. It get's "blotchy" very easily- especially with light to medium colors. If you do go with a stain/dye finish, you HAVE to use pre-stain wood conditioner on the whole body. It's very easy to use and can be found in any hardware store that carries stains. It's also cheap to buy. The conditioner will help even out the colors by filling in some of the open grain before the color can get in to it.
I also would suggest wipe-on poly as a top coat for a newbie. It's the easiest to work with, it's pretty fool proof, and gives a decent, if not perfectly, glossy finish.
RGTFanatic is offline
post #4 of 6 (permalink) Old 05-20-2015, 07:55 AM Thread Starter
Thanks for the info! Much appreciated.
My plan is to use sand and sealer and then use an alcohol based dye. I would like the color to be light blue, so that the dye particles collect in the carvings that make up the design, which will hopefully result in a darker blue outline. Then I will shoot a clear coat and hopefully have a beautiful guitar, but I guess it depends on how the basswood reacts to the dye.
As far as the rest of the guitar, I already have an MIJ RG570 neck to go with the body. Also not sure of the color scheme for the hardware. I'm thinking black, but maybe gold would look nice with the blue. I have a 7 string Ibanez, but I'm hoping this will be my main 6 string. I'll slap some Crunchlab/Liquifires in there and this thing will be a beauty. I hope. In any case, this is a fun project and definitely a learning experience.
post #5 of 6 (permalink) Old 05-23-2015, 09:12 AM
be sure to post pics of your progress!
dgbaker33 is offline
post #6 of 6 (permalink) Old 05-23-2015, 10:28 AM
SYL
I've always loved these bodies but never pulled the trigger - good luck with it as the suggestion above sounds amazing
SYL is offline
basswood , finishing , ibanez , jpm
Project Seafarer: My first project 540R SH, (Long thread warning!!) satchmo72 All Other Guitars (including Prestige) 16 04-03-2011 08:05 AM
Ever wondered how much your project will cost ?? Post project costs here ! Jaden Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 12 08-29-2006 07:48 PM
recording project isn't looking good - recording project isn shredmaster Ibanez JEM, UV, JS & Other Signature Models 8 11-12-2001 10:17 AM
Project Axes - project guitars Bradly Smith All Other Guitars (including Prestige) 4 10-09-2001 06:50 PM
Project Guitar Ideas - Opinions wanted on project jem7vwh Tech: Setup, Repairs and Mods 11 12-19-2000 11:27 PM
