Need help with lo-pro trem angle... - Jemsite
post #1 of 5 (permalink) Old 08-27-2004, 09:51 PM Thread Starter
Should the trem angle be parallel with the guitar body or slightly raised? In the instruction manual is sez parallel but, on some sites they say it should be slightly raised. I'm trying to get it parallel. I adust the spring tension. Then i tune the guitar. Then the angle changes. Then i have to tune again. Is this common to go through this back and forth adjusting angle and tuning? Any help would much appreciated, thanx.
ibanezlover is offline
post #2 of 5 (permalink) Old 08-27-2004, 10:20 PM
Kontalonis is offline
post #3 of 5 (permalink) Old 08-27-2004, 10:26 PM
You've seen this, right?
It's common to have to go through a bit of trial and error in adjusting the spring tension and then retuning for several iterations. Once done, it pretty well stays put unless you change string gauges. (e.g. go from 0.009s to 0.010s or something.)
The top surface of the lo-pro edge is angled compared to the knife edges, as I recall. You want the knife edges parallel to the strings, and perpendicular to the trem posts, which means the top surface of the trem will be at a bit of an angle compared to the body of an RG, or even more so compared to an S series. Have a look at the pics in that link.
Also, see this to help with tuning more quickly.
http://www.ibanezrules.com/tech/setup/tuning.htm
Ferrous Lepidoptera is offline
post #4 of 5 (permalink) Old 08-27-2004, 10:33 PM
Re: Need help with lo-pro trem angle...
The "manual" is referring to the bottom of the baseplate, it just doesn't specify that.
Rich is offline
post #5 of 5 (permalink) Old 08-27-2004, 10:50 PM Thread Starter
Thanks for the quick replies everyone.
guitar body , pro edge , string gauges
Trem Angle Ke^in All Other Guitars (including Prestige) 7 04-09-2012 08:23 AM
lo -pro trem angle jem_fanatic Tech: Setup, Repairs and Mods 8 06-23-2006 09:49 AM
Trem Angle klp2332 Tech: Setup, Repairs and Mods 17 02-10-2006 07:26 AM
Trem angle B1Zzar3 Tech: Setup, Repairs and Mods 5 01-24-2005 10:36 AM
Trem angle wangbar Tech: Setup, Repairs and Mods 8 11-25-2003 05:37 PM
