Need help with my RG Paint 2-- Video showing the issue - Jemsite
post #1 of 9 (permalink) Old 12-10-2009, 03:03 AM Thread Starter
IbanezFreak777's Avatar
Reviews: 25
Hi all
My Floyd Rose is having an issue, best way to describe it, is to show you on youtube.
I have had this guitar strung up and its plays fine and never has issues, its just when the strings are off that I have this problem.
My other RG paint 1 which is identical, bar the PUPs doesn't have this issue...
thanks for any help that anyone can provide
http://www.youtube.com/watch?v=EX6GunWpuRQ
IbanezFreak777 is offline
post #2 of 9 (permalink) Old 12-10-2009, 03:10 AM
Re: Need help with my RG Paint 2-- Video showing the issue
does it happen with the strings on...?
woops, read the post properly.
does it matter...? as long as when the strings are off and the trem is level it should be fine. maybe the trem post is worn out.
Homebake is offline
post #3 of 9 (permalink) Old 12-10-2009, 03:25 AM
Its just because there is no tension from the strings. When you pull on the bar, the knife edge is sliding on the post. Theres not a whole lot of contact area there, so there will be very little friction to keep it in place, so it moves quite easily.
littlephil is offline
post #4 of 9 (permalink) Old 12-10-2009, 03:59 AM Thread Starter
Reviews: 25
thanks fo the response
Look it doesn't matter when the guitar is strung up, cause she plays awesome, I just want to know if this is an actual problem that I have to be worried about..
post #5 of 9 (permalink) Old 12-10-2009, 05:53 PM
No, it's normal.
Bildi is offline
post #6 of 9 (permalink) Old 12-10-2009, 07:00 PM
Guitars are supposed to be used with strings on, so I think there's no problem.
Mr. Killer is offline
post #7 of 9 (permalink) Old 12-10-2009, 07:24 PM Thread Starter
Reviews: 25
well none of my other guitars do that when the strings are off thats why I asked
post #8 of 9 (permalink) Old 12-10-2009, 07:29 PM
Spring tension perhaps??
post #9 of 9 (permalink) Old 12-10-2009, 07:45 PM
All my Ibanez's with Lo-Pros and locking studs will do it to various degrees (I don't have any other Ibanez hardware combos so I don't know about them). It only takes a small difference in angles to change how easily it happens, but since your priority is setting up the guitar to be correct when it's strung, it doesn't really matter what it does when it's unstrung.
I think the main thing is to ensure the trem doesn't slip and knock any paintwork, I've never had that happen but maybe it could if you were unlucky.
Bildi is offline
Showing my age? NGD DavyH All Other Guitars (including Prestige) 12 12-08-2008 07:23 AM
Chibanez showing up at Guitar Center HDS Vendors, Auction & Reseller Talk 3 10-26-2008 11:25 PM
Showing off my new JS1000BP guitarnoize Ibanez JEM, UV, JS & Other Signature Models 6 10-20-2008 12:49 AM
Help...how should I handle this paint issue MCR Tech: Setup, Repairs and Mods 5 01-18-2007 05:25 PM
anyone going to the midnight star wars showing? shredmaster Off-topic / Miscellaneous 24 05-20-2005 12:11 AM
