Need help with tone - Jemsite
post #1 of 6 (permalink) Old 01-27-2012, 02:19 AM Thread Starter
Need help with tone
I am starting this thread because I currently have a guitar that I have tried a few things with, and I just can't get it to sound right. I have an RG1420 that sounds incredible. I am 1000% happy with the tone of this thing. It has the stock pickups (V6) but I don't want to change anything because it just sounds killer.
So, I also have a Carvin Bolt+. It is alder with maple neck and board. I have used the stock Carvin pickups and a JB in the bridge and both pickups had the same problem... It sounds really compressed and somewhat fizzy in the mids. I HATE the compression. It is also a bit woofier in the lows. My Ibanez has none of this whatsoever.
I am debating buying some Dimarzios for it before I just give up on it for good, but I just don't know enough about this to know what to get. I know the V6 is ceramic but not huge output, but it's enough for me. What exactly will get rid of the compression? I can adjust the EQ on my amp as much as I want, and it changes tone obviously, but that compression is still there. I don't know if I should look for a pickup with a ceramic magnet, high or low output, low mids, high mids... No idea.
FWIW, my amp is a Carvin V3M which has been re-tubed with JJ's in the power section and Tung-Sol's in the pre-amp section.
Potatohead_33 is offline
post #2 of 6 (permalink) Old 01-27-2012, 03:02 AM
Re: Need help with tone
So it sounds like you enjoy the sound of a warmer pickup with responive mids, a smooth high end and booming bass?
sebastian is offline
post #3 of 6 (permalink) Old 01-27-2012, 03:26 AM
You are describing what every SD pickup sounds like to some extent, they definitely have an, umm.. *character. You either like it or you don't, you obviously don't.
Try some Dimarzios, or bare knuckles, or Gibsons, Bill Lawrence, you get the point. Pups have a HUGE amount to do with what you hear from the guitar, play around and find what works for you.
musikron is offline
post #4 of 6 (permalink) Old 01-27-2012, 06:35 AM
+1.
You could start with putting the V6 in the Carvin and just try it out, see wat it sounds like.
Then you have something to go from.
You probably still want to go for a "warmer" sounding pu (then the V6)because of the maple and ash.
Death.by.G-string is offline
post #5 of 6 (permalink) Old 01-27-2012, 11:36 AM Thread Starter
I would agree with that. I mainly play thrash type metal with these two guitars... Megadeth, older Metallica, etc. For example the ending riff in For Whom the Bell Tolls, those power chords just sound so compressed and fizzy. I just don't like it, at all. With my Ibanez they sound great.
I think I will try some Dimarzios, I really hope this solves this problem but from what I have been reading, it should solve most of it.
Originally Posted by Death.by.G-string View Post
+1.
Well, the V3M is a really dark amp, so I don't need to go too warm I guess.
Any suggestions from anyone? I usually keep my Carvin in Eb or drop C# also. I was thinking something like an Evo2, CrunchLab or even Super Distortion for the bridge (my main concern). I also have another RG with an 81/85 set which I have the same problem, but it's not as bad. I think I will try D-Activators in that one eventually. You guys are making me feel better though, I was *this* close to putting the Carvin on Craigslist last night... I will at least try some Dimarzios first.
post #6 of 6 (permalink) Old 01-27-2012, 11:51 AM
If your a metal man, get the original Tone Zone, not the Air Zone.
1420 , 1421 , carvin , ibanez , tone
Malmsteen Tone and tone in general rosskoss Gear, Equipment, Recording & Off Topic 17 01-06-2009 02:13 AM
Tone opinion; is this an ok tone? leec Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 10 03-28-2007 01:35 PM
the TONE ZONE? best bet for a les paul type tone from a ibanez? Roadstar Pickups & wiring 1 08-19-2005 12:06 PM
Power tube tone vs. SS tone (not preamp) revsharp777 Gear, Equipment, Recording & Off Topic 20 06-08-2005 01:13 AM
Tone like corn chips... - tone advice appreciated Goofy Gear, Equipment, Recording & Off Topic 2 12-31-2000 01:43 AM
