Need quick help with Edge Pro 7 - Jemsite
post #1 of 8 (permalink) Old 03-26-2007, 04:48 PM Thread Starter
I just got my 1527 and I'm having some trouble with the trem. I almost have the springs screwed in all the way to the body and the trem is still too high when I tune to standard. It's like the springs are too loose.
Any help?
Metallic00 is offline
post #2 of 8 (permalink) Old 03-26-2007, 04:54 PM
Re: Need quick help with Edge Pro 7
How many spring you got on 3? Try moving them so they are like /I\ gives them more pull.
Mission1979 is offline
post #3 of 8 (permalink) Old 03-26-2007, 05:00 PM Thread Starter
Can I move them with strings on the guitar? How should I go about doing that?
post #4 of 8 (permalink) Old 03-26-2007, 05:50 PM
You'll have to slacken them off quite a bit then get some needle nosed pliers and lift the hooped end over the hook very carefully, if you slip you damage the body. Let the spring relax first don't try to do it all in one movement. Re-establish grip and hook it over the hook nearer the centre. Try leaving trem arm in, turning it 180 so it sticks out the back and press down a little on it so it slackens the strings even more if necessary.
What gauge string are you using, Ibanez floating bridges are usually set up to take 9's to 54(ish) on the Low B
post #5 of 8 (permalink) Old 03-27-2007, 05:59 AM
Jaden's Avatar
add a spring...... !
Jaden is offline
post #6 of 8 (permalink) Old 03-27-2007, 09:22 AM
jb4674's Avatar
Reviews: 18
It's probably the gauge of the strings you're using, particularly the 7th string. How is the action on the guitar? Is it high? If the action is high, then you need to lower the trem.
Jimmy
jb4674 is offline
post #7 of 8 (permalink) Old 03-27-2007, 12:12 PM
I've got guage 9s on my s7420 and i need 5 springs to balance them
Satchriossi is offline
post #8 of 8 (permalink) Old 03-27-2007, 12:30 PM
jb4674's Avatar
Reviews: 18
Something's definitely wrong with that. Post a pic of the trem cavity.
jb4674 is offline
floating bridges , trem arm
Edge III swap for another Edge model trem? lespaulreedsmith All Other Guitars (including Prestige) 39 12-21-2017 06:11 PM
edge pro to lo pro rya Ibanez JEM, UV, JS & Other Signature Models 54 11-11-2012 03:24 PM
Edge mysteries solved!!......? - Answers to some common ques Jason Stone Tech: Setup, Repairs and Mods 18 05-27-2008 08:35 AM
edge, lo pro and edge pro are 100% drop in fit dex Tech: Setup, Repairs and Mods 47 10-18-2005 11:29 AM
Quick Tuning on Lo Pro Edge 7 - Trem Block Question rlintz All Other Guitars (including Prestige) 5 08-12-2001 02:45 PM
